[QGIS-Developer] [Poll created] Re: "Human In The Loop" Policy For AI/Tool-Assisted Contributions
Martin Dobias wonder.sk at gmail.com
Wed Feb 11 07:03:56 PST 2026
Hi all
My perspective on AI tools is that it's just another tool in a developer's
toolbox, just like a debugger or a code analyzer.
There are lots of unknowns about the training data, I agree. But being
conservative and adopting a strict no AI tools policy seems like
restricting ourselves from using the best tools for the job. In the end, it
is still the responsibility of the developer to ensure their contribution
is correct, and not violating copyright, whether they use AI tools or not.
It is also hard to draw a line for a conservative "no AI" policy:
- is it acceptable to brainstorm design with AI?
- is it acceptable to get a prototype built with AI, for inspiration?
- is it acceptable to get AI to check code for bugs?
- is it acceptable to ask AI to improve tone of my reviews?
With strict no AI policy, I guess we would also need to make sure that all
of the 50+ dependencies also have strict no AI policy, otherwise QGIS
builds could still in theory contain AI-generated copyrighted code? I am
not sure that is realistic...
Let's be pragmatic: AI tools are here to stay, we can either ignore them,
or we can learn to use them responsibly to deliver even more QGIS goodness
:-) And we can expect that with the increased risk of copyright issues,
there will be automated tools to scan the code for possible copyright
problems, integrated in CI, which will flag any risky contributions.
Cheers
Martin
On Tue, Feb 10, 2026 at 6:06 PM Vincent Picavet via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hello,
> On 07/02/2026 00:30, Even Rouault wrote:
> > Thanks for your feedback. Yes copyright / IP issues are a tricky problem
> to deal with and you make good points on how things could go wrong. That
> said, in practice I believe most generated code would be mostly derived
> from QGIS itself, QT code or doc or be non-copyrightable material. I can
> I seriously doubt that, given the amount of copyrighted material that has
> already been used to train LLMs. And most important, we have no way to know
> that, except if the LLM companies get subpoenaed and disclose hidden
> practices when asked in court.
> Believing is not enough when talking about legal stuff.
> > imagine though that contributions including non-trivial algorithms could
> possibly be infringing copyright. In that situation, the reviewers could
> ask the
> Even simpler code can be plagiarized, not only non-trivial algorithms.
> > submitter to bring more light on the provenance of such code (the
> contributor may ask the LLM to dig for references for the provenance and
> check they are OK with GPL2 inclusion, being aware that the LLM could
> hallucinate them...), and if no satisfactory answer is given, reject the
> contribution. But that can be admitedly hard to spot for reviewers. I'd be
> happy to amend the QEP with that if someone can propose an adequate
> formulation.
> Again, a reviewer has no way to know or imagine that a code has been
> plagiarized : you would have to be aware of the full training dataset of
> the LLM, and this is 1. behind closed fences 2. not humanly possible.
> > I've doubts a "no AI" policy is achievable in practice, or people will
> lie.  As you mention, we can require people to mention the tool they have
> used, possibly the prompt(s) they use, which manual modifications they
> applied on top of that.  Doesn't the paragraph starting at line 35 (
> https://github.com/qgis/QGIS-Enhancement-Proposals/pull/363/changes#diff-4f4102e51f04fdfc82e843c6942abe9965c03ac85a92e9becf21bcca8b5571adR35)
> cover enough your point about "have a mandatory mention and description of
> LLM usage for each contribution" ?
> Lying about not using AI is just like lying about being sure one has the
> right to contribute the code ( see contributor's agreement ) : if this is a
> rule, we ask people and they lie, then we should also have sanctions and be
> strict about it.
> For me, full transparency about usage of a blackbox **for code
> generation** is not enough as a protection against legal matters. For
> anything else that can be AI-aided, this is more about resiliency,
> transparency and trust, and we should make it clear that explaining exactly
> how AI has been used is mandatory and should be given along every
> contribution.
> > The main driver for this QEP was to give us a tool to be able to quickly
> reject sloppy contributions with a solid reference to back our decisions,
> but we must indeed decide whether we go further than this.
> I guess there is matter to debate and a lot of uncertainty. Hence the
> conservative approach, to avoid the worst and maybe open it later on
> whenever we see the situation clearer.
> > For that purpose, I've created a quick poll at
> https://docs.google.com/forms/d/e/1FAIpQLSdnVWoD5DrwCbNXqPqHsLw2jfbLkPMKBkvfyQfTQOPZkj_EaQ/viewform
> so we can gather opinions on the general direction we want on that subject.
> All, please fill!
> Ok to gather more advice, thanks for running the poll,
> Vincent
> > Even
> > Le 06/02/2026 à 18:01, Vincent Picavet via QGIS-Developer a écrit :
> >> Hi,
> >> I would double-down on Greg Troxel's advice concerning copyright
> issues, especially concerning the introduction of LLM-generated code into
> QGIS codebase.
> >> Opensource's success is based on these main characteristics : quality,
> security, trust.
> >> AI contributions pose a threat to quality, security and trust alike.
> >> A human-in-the-loop policy for contributions written with AI may help
> for quality and security issues, but will still leaves a huge problem for
> trust.
> >> Among the various aspects of trust, what worries me most right now is
> the copyright issue. OpenSource software is based on intellectual property
> laws, and especially on copyright, to be able to derive copyleft and grant
> more rights to end-users.
> >> End-user trust opensource software from a legal point of view because :
> >> - they are backed by well-established copyright laws
> >> - they have clear and well established end-users contracts ( opensource
> licences )
> >> - they have a full record of modifications of the source code, hence a
> full lineage and certification of IP rights for the code
> >> - also, foundations like OSGeo additionnaly put a stamp on the software
> to guarantee that process and initial IP can be trusted enough to have a
> legal insurance concerning the software
> >> Introducing IA black boxes into the development process breaks the
> ability to control the lineage of the code and guarantee that it is a
> genuine invention, and therefore allowed to be licenced under the GPL.
> >> For quality and security, a developer can always intrinsically assess
> that the generated code has the required level of quality, and that it does
> not include any security flaw.
> >> But **there is no way for a developer to evaluate the IP rights on a
> code generated by a LLM**. How would one do it, since the code has been
> generated through a total opaque black box ingesting non-identified
> enormous volumes of data ?
> >> Today, we definitely know that LLMs ( ChatGPT, Claude and others ) have
> been trained on illegal copyrighted material. It is proven that they
> trained LLMs on pirated books. Furthermore, every time someone complaints
> about IP violation by LLM, big corps settle a financial arrangement with
> the copyright owners and move on.
> >> There is therefore no doubt that they have also trained LLMs on
> proprietary code. And also on opensource code not compliant with GPLv2+.
> >> Big corp. currently hide behind a "fair use" argument, but this is
> clearly rubbish, otherwise why would they bother to settle large financial
> deals with copyright owners ?
> >> So, LLM-generated code contributed to QGIS will at some point be
> plagiarized from random code available on the internet, and neither
> QGIS.org nor the contributor will be able to know.
> >> If we start accepting such code without being able to check provenance
> or copyright issues, it will end up buried deep inside QGIS, and the day we
> will discover that it infringes copyright, it will be a nightmare to solve
> : in this case we will want to revert all incriminated code, and also all
> code depending on the plagiarized code **and have it rewritten from scratch
> by someone who has never read the plagiarized code** ( ref : SCO/UNIX for
> example ). This is almost impossible.
> >> This would be a nightmare, just for one identified contribution.
> >> Even more, if/when the fair-use principle of LLMs falls down, then all
> LLM-generated code should be removed from QGIS, and all code depending on
> it. This is a really high risk with high impact.
> >> You may say : "ok but everyone does it, the chances of being caught are
> low, why not benefit from the opportunity ?"
> >> Then what about "everyone copies GPL code into proprietary code, the
> chances of being caught are low, why not benefit from the opportunity ?"
> >> Copyright is at the foundation of OpenSource software, and especially
> GPL-based software. If we choose to deny it, then we loose our core
> principle.
> >> In the text Even propose, there is a copyright section, pushing the
> responsibility of IP compliance control back to the contributor. It may
> protect QGIS.org or other developers from being sued whenever there is a
> problem, or they could sue back the faulty contributor, but this is not
> enough :
> >> - the faulty contributor has no way to ensure his generated code has no
> IP issue ( other than NOT using LLMs ) : responsibility without any mean of
> action is not fair and sustainable
> >> - even if the QGIS projet can avoid being convicted by transferring
> responsibility, then the situation would still be open and be a nightmare :
> removing plagiarized code entangled down the core of the software and all
> its dependency code, and rewrite it without IP issue is really hard
> >> Therefore, I do not think this mention is enough for IP protection.
> >> This rationale concerns the generated code itself, contributed to QGIS
> or other software in the ecosystem. LLMs may be useful and without IP risks
> to help find bugs, write parts of documentations where there is no risk of
> plagiarism, or other use cases.
> >> But I would definitely **forbid any generated code to be introduced
> into the main source code because of IP risk**.
> >> Also, the least we can do for any contribution, is not only to have a
> human in the loop, but also to have a mandatory mention and description of
> LLM usage for each contribution. This would at least give traceability. It
> does not solve anything, but in case of a problem, we could at least start
> to investigate.
> >> A am glad this conversation takes place, and willing to pursue the
> discussion, sorry for having been long.
> >> Have a nice weekend,
> >> Vincent
> >> On 31/01/2026 01:01, Greg Troxel via QGIS-Developer wrote:
> >>> I would suggest a much stronger policy:
> >>>    no LLM-generated code or discussion may be submitted to any QGIS
> forum
> >>> The idea that LLM-generated code has been "reviewed" intends to be that
> >>> it is of high enough quality that it is reasonable for *humans* to
> spend
> >>> time reviewing it.  But I don't believe that asking that it be reviewed
> >>> will achieve that in practice.
> >>> I've already had the experience (in a different project) of seeing a
> >>> posted PR(ish, patch on list), taking the time to comment, and getting
> >>> LLM-generated (vacuous) replies to my comments.
> >>> Besides the ethical problems with asking humans to review, improve,
> >>> judge or in any other way pay attention to LLM output, there's the
> >>> problem of copyright.  While machine-generated text isn't copyrightable
> >>> as is, LLM output is a derived work of stolen human work, scraped
> >>> and used without permission, often as DDOS.
> >>> On the basis of each reason, I believe the policy about LLM should just
> >>> be "no".
> >>> _______________________________________________
> >>> QGIS-Developer mailing list
> >>> QGIS-Developer at lists.osgeo.org
> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Hello,
> ask the
> formulation.
> strict about it.
> contribution.
> All, please fill!
> Vincent
> > Even
> >> Hi,
> QGIS codebase.
> security, trust.
> trust.
> licences )
> principle.
> enough :
> to investigate.
> >> Vincent
> forum
> spend
> >>> be "no".
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260211/eda4f154/attachment-0001.htm>
More information about the QGIS-Developer mailing list
