[QGIS-Developer] How does one deprecate a plugin correctly?
Raphael Das Gupta raphael.dasgupta at ost.ch
Fri Feb 13 02:29:00 PST 2026
Dear all
How does one deprecate one of one's own plugins correctly?
  * Should I set deprecated=True in metadata.txt and re-upload the plugin?
      o If so, should I also bump the version number, or upload a thusly
        changed copy of the so-far latest version?
  * Should I "Edit" the plugin on https://plugins.qgis.org/plugins/my
    and check the "Deprecated" checkbox?
  * Does it matter whether I do just one of those or both?
Is the process documented anywhere? I couldn't find detailed
instructions for this.
Best regards,
Raphael
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260213/9fef6aaa/attachment.htm>
More information about the QGIS-Developer mailing list
