[QGIS-Developer] Plugins’ Dual QGIS 3 and QGIS 4 Compatibility
Richard Duivenvoorde rdmailings at duif.net
Thu Feb 26 02:39:24 PST 2026
Hi Borys,
I fully agree with your analysis (cc'ing lova which is doing current plugins server software).
My choice would be your option 2: dropping the Qt6 tag etc etc
So what about doing this for QGIS4 only? Would that be an option?
When we move to QGIS4/Qt6 metadata and plugins have to be updated anyway.
Others?
Regards.
On 2/24/26 21:35, Borys Jurgiel via QGIS-Developer wrote:
> I just realized that our mess with the `qgis_maximum_version` tag is escalating, and this may be the last moment to rethink whether we really want it to be set automatically.
> Years ago, I introduced this tag to the plugin installer in order to extend the compatibility range to more than one major version, which is exactly our current case. At the same time, @ElPaso implemented it in the repository application, but somehow we didn’t fully align on the idea: for me it was optional and not meant to be set by default. When it is missing, the plugin installer assumes compatibility up to the very end of the same major version. On the other hand, the repository always sets it to x.99 if it is not present. Many authors then assumed it was mandatory and started tagging plugins as x.99 or x.98. I guess we never really discussed this topic, and now we have a full variety of `qgis_maximum_version` values: either explicitly set by authors or automatically added by the repository. Furthermore, in recent years, the `qt6_compatible` tag was introduced, which made perfect sense at the time. However, it is now redundant if at least one of the version bounds is set
> to >= 4.0.
> Everything worked well as long as the PyQGIS API version was 3.99. When it was bumped to 4.0 last year (not to be confused with the general QGIS version), all Qt6-compatible plugins without `qgis_maximum_version` explicitly set to 4 became broken:
> https://github.com/qgis/QGIS/issues/62359
> @JEF partially fixed this in:
> https://github.com/jef-n/QGIS/commit/eac401c009f11f58c0ac2253c98d35ec6338ca60
> However, this only fixed loading plugins that were already installed in QGIS 3. In QGIS 4, they are not available from the official repository, so it is impossible to (re)install them. This happens because the condition `if not qgisMaximumVersion (...) and supports_qt6`: fails twice, as the official repository always returns the `qgis_maximum_version` and never returns `supports_qt6`.
> This is very unexpected behaviour, so many plugin authors explicitly set `qgis_maximum_version` to 4.99 in their plugins, what is actually how the tag was originally intended to be used in the installer. Currently, there are 171 or 182 such plugins in the official repository with `qgis_maximum_version` explicitly set to >= 4.0 (I don't know how many Qt6-compatible plugins are in the repo in total).
> I can see two straightforward ways to fix this issue, but they raise a strategic question: do we really want `qgis_maximum_version` to be completed automatically?
> 1: If we want the function of forcibly bumping Qt6 plugins from 3.x to 4.99 to work properly, it simply needs to be implemented in the official repository application as well, so that such plugins are exposed to the installer as 4.99 rather than 3.99.
> Pros: everything will work as expected.
> Cons: we introduce that rather nasty hardcoded 4.99 for a couple of years, and anybody will understand how it works in detail.
> 2: Or should we return to the original idea: make `qgis_maximum_version` optional, stop adding it in the repository when it is not present (and only handle it internally when resolving the version filter), and strictly require plugin authors to set this tag if they want to support dual major versions? In this scenario, we should also drop the qt6_compatible tag.
> Pros: we keep things simple and unambiguous.
> Cons: we break unprepared plugins until their metadata are updated.
> Personally, I’m fine with either solution, but with this rather long story I just wanted to provide some context on how we ended up here. Thanks to anyone who made it to the end :)
> Borys
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
