[QGIS-Developer] qgis builds from release-nightly repo not built with QGISDEBUG?
Sandro Mani
manisandro at gmail.com
Fri Jan 16 06:11:52 PST 2026
Hi
I'm trying to obtain debug output from qgis-server from the
release-nighly repo (currently testing with
1:3.44.6+git20260114+3cbba756601+40noble), which according to [1] is
compiled as a debug build (so as I understand should have #define
QGISDEBUG?).
I wrote a small plugin which does
QgsMessageLog.logMessage("QGIS_DEBUG: %s" % os.environ.get('QGIS_DEBUG',
'<unset>'), 'Server Plugin "DebugTest"', Qgis.Info)
QgsMessageLog.logMessage("Level: %d" % QgsLogger.debugLevel(), 'Server
QgsLogger.debug("This is a debug message", 0, "debug.py",
"onRequestReady", 18)
and then call the qgis server as
QGIS_SERVER_LOG_FILE=$PWD/qgis_server.log QGIS_LOG_FILE=$PWD/qgis.log
QGIS_PROJECT_FILE=$PWD/test.qgs
QUERY_STRING="SERVICE=WMS&REQUEST=GetCapabilities"
/usr/lib/cgi-bin/qgis_mapserv.fcgi
The relevant output is in qgis_server.log
13:52:41 INFO Server Plugin "DebugTest"[558]: QGIS_DEBUG: <unset>
13:52:41 INFO Server Plugin "DebugTest"[558]: Level: 0
while qgis.log is empty. If I manually set QGIS_DEBUG=1, qgis.log will
contain
debug.py:18 : (onRequestReady) [3ms] This is a debug message
So it looks like the release-nighly builds are in fact not compiled with
QGISDEBUG, and all QgsDebug macros [2] are compiled as stubs? Are the
build logs of the release-nighly repo visible somewhere?
Thanks!
Sandro
[1] https://qgis.org/resources/installation-guide/#debian--ubuntu
[2]
https://github.com/qgis/QGIS/blob/fb066c580586d9a01aeec95276a279a2adb686ad/src/core/qgslogger.h#L32
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260116/3a9ee656/attachment.htm>
