[QGIS-Developer] SAP HANA on MacOS
Matthias Kuhn
matthias at opengis.ch
Fri Jan 30 00:50:48 PST 2026
Hi Florian,
Yes, the packages are produced using the build-macos-qt6 workflow.
One thing I'd also suggest is to make it possible use the odbccpp library
as an external dependency (compared to the current vendored copy), this
would allow us to cache the prebuilt package in the workflow runs and
support performance in our CI/CD pipelines.
This would require a few tweaks like adding a vcpkg port, use a cmake
target to link to the library and adding a cmake toggle to switch between
using the vendored and an externally provided copy.
Thanks
Matthias
On Thu, Jan 29, 2026 at 8:46 AM Schimmel, Florian via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi,
> I’m a developer in the geospatial team of SAP HANA. We were noticed that
> HANA is not available on the new releases of QGIS on MacOS. I built it
> locally and it is available with the WITH_HANA=TRUE option in cmake. So, I
> think it's simply not added during the release process, maybe after the
> switch to qt6 and the use of vcpkg. I’m not sure about the exact process,
> which creates the releases. Would it suffice to add it in the
> build-macos-qt6
> <https://github.com/qgis/QGIS/blob/404776a21836daf0e9b1b7c21590ff48680dd0fa/.github/workflows/build-macos-qt6.yml> workflow?
> And if so, would it be ok to do this? In that case I would open a
> pull-request. Let me know if I’m missing something. I will happily check
> again.
> Thanks for taking the time,
> Florian
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260130/0607947c/attachment.htm>
