[QGIS-Developer] PostgreSQL vulnerability in the QGIS application
HarishKumar J, (Springbord)
harishkumar.jayakumar at springbord.com
Thu Jul 2 00:33:09 PDT 2026
Dear Dror,
Thank you for the clarification regarding the bundled installations.
Based on your recommendation to use the Long Term Release (LTR) version for
organizational settings, we will look into the current LTR 3.44. We will
also monitor the upcoming release of QGIS 4.2.4 in October.
Since QGIS does not come with a prebundled PostgreSQL installation, we will
investigate our internal deployment process to identify how PostgreSQL
17.0.3 was included and proceed with the necessary upgrades independently.
Thanks
Harish
On Thu, Jul 2, 2026 at 12:17 PM Dror Bogin <dror.bogin at gmail.com> wrote:
> Hi Harish,
> Neither the standalone nor the OSGeo4W installations of QGIS come with a
> prebundled PostgreSQL installation.
> Since it sounds like you installed QGIS in an organization, it is mostly
> recommended to use the LTR (Long Term Release) version (currently 3.44) in
> that setting, not the newest version.
> The first LTR of QGIS 4.x is planned to release in October, with QGIS
> 4.2.4.
> On Thu, 2 Jul 2026 at 08:48, HarishKumar J, (Springbord) via
> QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
>> Hi There,
>> I hope you are well!
>> We are currently using QGIS version 4.0.3 and have identified that it
>> comes bundled with PostgreSQL version 17.0.3.
>> Our security monitoring has flagged multiple high-priority
>> vulnerabilities within this version of PostgreSQL (including CVE-2025-4207
>> and others). According to PostgreSQL security recommendations, a secure
>> version would be 17.10 or higher.
>> Could you please confirm if there is a newer release of QGIS that bundles
>> a secure version of PostgreSQL? Additionally, if a bundled update is not
>> yet available, please advise on the recommended process for upgrading the
>> internal PostgreSQL component to version 17.10 or above without impacting
>> the QGIS application's stability.
>> Thanks,
>> Harish
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260702/b850bed9/attachment.htm>
