[QGIS-Developer] SIP is insane
Alessandro Pasotti
apasotti at gmail.com
Sat Jun 6 09:40:27 PDT 2026
Hi Even,
I hear your scream and I scream with you :)
Something has definitely worsened after the shift to QT6 (even if I'm
not sure if the QT version has anything to do).
I've come to the point where I cannot build QGIS on my laptop (16GB
RAM 4 physical cores) anymore and even on my office PC (32 GB RAM and
8 physical cores) it occasionally crashes for OOM or freezes.
All the times that it happened, sip-build was eating up all resources.
I am sorry this is just a "me too" and I have no solution for this issue.
On Sat, Jun 6, 2026 at 3:16 AM Even Rouault via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> Hi,
> sorry for the eye-catching email title, couldn't resist.
> Am I the only QGIS dev highly frustrated by the bottleneck of sip-build
> when building QGIS? Can we do something (funding upstream?) to improve that?
> Also some mind bogging stats:
> - size of all QGIS headers: find ../src -name "*.h" -exec cat {} \; |
> wc -l : 570 288
> - size of QGIS .cpp + .ui: find ../src \( -name "*.cpp" -o -name "*.ui"
> \) -exec cat {} \; | wc -l : 1 497 216
> So QGIS is just a 2 million LoC (excluding tests) code base
> - size of .sip generated files: find . -name "*.sip" -exec cat {} \; |
> wc -l : 335 425
> - size of SIP generated .cpp files: find python/ -name "*.cpp" -exec
> cat {} \; | wc -l: 7 532 645 . 7.5 millions LoC !!!
> - size of MOC generated .cpp files: find src/ -name "*.cpp" -exec cat {}
> \; | wc -l : 2 051 769
> So 2 observations:
> - we bind to Python a very large part of our header files (more than
> half). I've always found that the amount of things exposed to Python was
> excessive. IMHO we should be much more conservative, and wait for plugin
> authors to ask for an API to be exposed, rather than expose it prematurely.
> - SIP generates > 20 times more lines of .cpp than .sip files!!! Or
> 3.75 times more lines of code than QGIS actual logic.
> That shows in (stripped) .so files:
> - output/python/qgis/*.so : 130 MB
> - output/lib/*.so.4.1.0 : 170 MB.
> So not as crazy as the 7.5 vs 2 MLOC of ratio, but still.
> Comparison with GDAL and SWIG:
> - size of public .h headers: 50 162 .
> - size of Python SWIG source .i files: ~43 000 (hard to count exactly
> as there's some bits of Java and C# in this count)
> - size of SWIG Python generated .cpp files: 164 151 .
> So a 4x only ratio of .cpp vs .i
> I don't recommend SWIG, but something looks fishy in the kingdom of SIP
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
