[QGIS-Developer] Limiting 3.44 backports?
Andrea Giudiceandrea
andreaerdna at libero.it
Fri Jun 12 05:21:00 PDT 2026
Hi list,
anyway it looks like it is currently not possible to merge approved PRs
in release-3_44 branch, due to the fact that the "Windows Qt6 / build
(windows)" check is still running and failing [1] or it is still
considered a required check while not actually running [2], although
such workflow has been disabled [3].
Similarly, in PRs for in queued_ltr_backports the same workflow is still
running (and failing) and it is considered a requested check, while it
should be disabled.
Regards.
Andrea
[1] https://github.com/qgis/QGIS/pull/66325
[2] https://github.com/qgis/QGIS/pull/66417
[2] https://github.com/qgis/QGIS/pull/66378
