[QGIS-Developer] SAP HANA on MacOS
Schimmel, Florian florian.schimmel at sap.com
Mon Jun 15 23:59:38 PDT 2026
Hey,
I noticed that the vcpkg commit hash was updated, so I added the odbccpp library in another change<https://github.com/qgis/QGIS/pull/66470>. I hope this works and makes it able to cache in in nuget. I hope this is fine, let me know if there is something missing.
Best regards,
Florian
From: Schimmel, Florian <florian.schimmel at sap.com>
Date: Friday, 22. May 2026 at 15:21
To: Even Rouault <even.rouault at spatialys.com>; Matthias Kuhn <matthias at opengis.ch>
Cc: qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>
Subject: Re: [QGIS-Developer] SAP HANA on MacOS
Hey,
It was a bit of a hassle and took a while to add the odbccpp package to vcpkg<https://github.com/microsoft/vcpkg/pull/50152>, but it is now available. I created a change to include it in QGIS by vcpkg, but bumping up the vcpkg commit hash didn’t work because goal can’t build with the newest version of poppler. For me, it seems like a known problem and the best solution would bet to wait for the updates of the packages in vcpkg. I will add the odbccpp wrapper by vcpkg when this is solved.
In the meantime, I added already a change to enable HANA<https://github.com/qgis/QGIS/pull/66205>, I hope this is fine. Let me know, if there are any issues.
Best regards,
Florian
Date: Friday, 20. February 2026 at 15:47
Hey Even,
Thanks for the hint, that makes sense. I will add it to the vcpkg repo and note this thread again after it is merged and the QGIS change is pushed.
Best regards
Florian
Date: Friday, 20. February 2026 at 01:37
To: Schimmel, Florian <florian.schimmel at sap.com>, Matthias Kuhn <matthias at opengis.ch>
You don't often get email from even.rouault at spatialys.com. Learn why this is important<https://aka.ms/LearnAboutSenderIdentification>
Le 19/02/2026 à 18:04, Schimmel, Florian via QGIS-Developer a écrit :
Hey Matthias,
thank you for the reply, I like the idea and tried to implement it. I had to work into vcpkg and solve a few issues on the way, that took a while, but I have a working port now. While checking if it is possible to integrate the port in the QGIS build I noticed that there are custom ports in the repository. Since odbccpp is not broadly used, there is probably no application for a vcpkg port outside of QGIS, so would you mind if we add the port directly to the QGIS repository?
The GDAL HANA driver depends on odbccpp too, so for GDAL vcpkg users, having a standalone port could make sense
http://www.spatialys.com<http://www.spatialys.com/>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260616/ff4a277e/attachment-0001.htm>
More information about the QGIS-Developer mailing list
