[QGIS-Developer] Two Spatialite providers in QGIS. Remove one of them?
Tobias Schula
geospatial at schula.org
Tue Jun 23 05:17:33 PDT 2026
Hi list,
I'm currently running into all kinds of weird problems while working
with Spatialite-databases. For example:
> https://github.com/qgis/QGIS/issues/66329
I haven't even written down yet the issues I'm facing with foreign key
constraints and triggers. Because I found already a solution: Don't use
the Spatialite provider, but OGR. It will respect foreign key
constraints and even load them while adding the layers. It also
automatically sets up the autogenerate form with appropriate input
fields like "range" for `INTEGER` and "text" for `NUMERIC`/`REAL`.
There are also other problems with the Spatialite data provider, that
don't occur when using GDAL/OGR:
> https://github.com/qgis/QGIS/issues/48390
Is there a reason QGIS is still carrying the Spatialite provider? Can it
be fully replaced with OGR? OGR is coming with Spatialite support ootb
anyway, why would QGIS bring two implementations?
Thus, I'd propose to remove the Spatialite provider, since OGR is
offering a more mature solution and removing a different implementation
with overlapping functionality would reduce the maintenance burden on
you developers.
Best regards
Tobias A Schula
Forestry Expert
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260623/13c02222/attachment-0001.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260623/13c02222/attachment-0001.sig>
