[QGIS-Developer] GSoC 2026 — Enhancing ogrinfo Processing Algorithms in QGIS
Sionigdha Sadhukhan snigdha.lee75 at gmail.com
Mon Mar 9 03:39:03 PDT 2026
Hi Valentin,
My name is Sionigdha and I'm interested in contributing to QGIS through
GSoC 2026.
While exploring the QGIS codebase I looked at OgrInfo.py in the GDAL
processing algorithms and noticed that several GDAL ogrinfo capabilities
are not exposed as typed parameters  specifically -fid, -where, -spat,
-geom, -fields, and -limit. Users currently have to use the raw EXTRA
string field to access these, which is undiscoverable and unusable in
processing models.
This caught my attention because I've been contributing to GDAL for the
past 3 months with multiple merged PRs including #13904 (adding --fid to
gdalinfo/GDALVectorInfo, merged in GDAL 3.13.0), #13812 (WMS/WMTS
network-dependent test improvements), and several documentation fixes. Full
list: https://github.com/OSGeo/gdal/pulls?q=author%3ASionigdha+is%3Amerged
I've also been contributing directly to QGIS including PR #64620 (merged
into QGIS 4.0.0) clarifying QgsLogger behavior, and several other
documentation PRs targeting 4.0.0. Full list:
https://github.com/qgis/QGIS/pulls?q=author%3ASionigdha+is%3Amerged
I'm currently working on building QGIS from source as per Exercise 0  my
machine has hardware constraints but I'm working through them.
I've been working on a prototype patch that adds -where, -fid, and -spat as
proper typed parameters to both ogrinfo and ogrinfojson, happy to share it
shortly.
My proposed project for GSoC would be:
1. Expose all missing ogrinfo parameters as typed, modelable inputs in both
2. Make ogrinfojson output structured and chainable within the processing
framework  field count, feature count, geometry type, extent as named
outputs
3. Add a new ogrfeatureinfo processing algorithm that takes a layer + FID
or WHERE clause and returns structured per-feature output  field values,
geometry type, WKT  usable as inputs in processing models
4. Full test coverage for all additions targeting QGIS 4.x
I'm comfortable in Python and PyQGIS, and I understand this targets QGIS
4.x with GDAL 3.13.0 as the baseline — which aligns directly with my GDAL
work.
Would you be open to discussing this as a GSoC 2026 proposal?
Best,
Sionigdha Sadhukhan
GitHub: https://github.com/Sionigdha
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260309/4b31b7b8/attachment.htm>
More information about the QGIS-Developer mailing list
