[QGIS-Developer] GSoC 2026 — Enhancing ogrinfo Processing Algorithms in QGIS
Sionigdha Sadhukhan snigdha.lee75 at gmail.com
Tue Mar 10 10:02:47 PDT 2026
Hi Valentin,
Thank you ,and thank you to Andrea as well. You're both right that EXTRA is
available as an advanced parameter in models. I overstated the problem and
will correct that framing.
Your point about scope is also fair. I've been thinking about the direction
you mentioned in improving JSON handling in the processing framework more
generally  and I think that's the right way to expand this. The rough shape
I'm exploring:
   - Extend ogrinfo/ogrinfojson: expose the missing typed parameters
   (-where, -fid, -sql, -spat, -geom, -fields, -limit) as proper inputs
   alongside EXTRA rather than replacing it
   - Add JSON handling algorithms to the processing framework along the
   lines of: LoadJSONFile (bring JSON data into a model), ExtractJSONValue
   (pull a specific value by key path for use in downstream steps),
   JSONToLayer (convert a JSON array to a vector layer with attributes)
   - ogrinfo jason's structured outputs  feature count, geometry type,
   extent  would serve as the first concrete demonstration: pipe the JSON
   output into ExtractJSONValue, feed the result into a conditional branch in
   the model
Since this direction is entirely Python and the processing framework, no
GDAL internals.I wanted to check whether you'd be comfortable mentoring it,
or whether you'd suggest someone else in the community to approach.
Happy to share a rough outline before writing a full draft.
Best, Sionigdha
On Mon, 9 Mar 2026 at 16:09, Sionigdha Sadhukhan <snigdha.lee75 at gmail.com>
wrote:
> Hi Valentin,
> My name is Sionigdha and I'm interested in contributing to QGIS through
> GSoC 2026.
> While exploring the QGIS codebase I looked at OgrInfo.py in the GDAL
> processing algorithms and noticed that several GDAL ogrinfo capabilities
> are not exposed as typed parameters  specifically -fid, -where, -spat,
> -geom, -fields, and -limit. Users currently have to use the raw EXTRA
> string field to access these, which is undiscoverable and unusable in
> processing models.
> This caught my attention because I've been contributing to GDAL for the
> past 3 months with multiple merged PRs including #13904 (adding --fid to
> gdalinfo/GDALVectorInfo, merged in GDAL 3.13.0), #13812 (WMS/WMTS
> network-dependent test improvements), and several documentation fixes. Full
> list: https://github.com/OSGeo/gdal/pulls?q=author%3ASionigdha+is%3Amerged
> I've also been contributing directly to QGIS including PR #64620 (merged
> into QGIS 4.0.0) clarifying QgsLogger behavior, and several other
> documentation PRs targeting 4.0.0. Full list:
> https://github.com/qgis/QGIS/pulls?q=author%3ASionigdha+is%3Amerged
> I'm currently working on building QGIS from source as per Exercise 0  my
> machine has hardware constraints but I'm working through them.
> I've been working on a prototype patch that adds -where, -fid, and -spat
> as proper typed parameters to both ogrinfo and ogrinfojson, happy to share
> it shortly.
> My proposed project for GSoC would be:
> 1. Expose all missing ogrinfo parameters as typed, modelable inputs in
> 2. Make ogrinfojson output structured and chainable within the processing
> framework  field count, feature count, geometry type, extent as named
> outputs
> 3. Add a new ogrfeatureinfo processing algorithm that takes a layer + FID
> or WHERE clause and returns structured per-feature output  field values,
> geometry type, WKT  usable as inputs in processing models
> 4. Full test coverage for all additions targeting QGIS 4.x
> I'm comfortable in Python and PyQGIS, and I understand this targets QGIS
> 4.x with GDAL 3.13.0 as the baseline — which aligns directly with my GDAL
> work.
> Would you be open to discussing this as a GSoC 2026 proposal?
> Best,
> Sionigdha Sadhukhan
> GitHub: https://github.com/Sionigdha
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260310/5f326fbc/attachment.htm>
More information about the QGIS-Developer mailing list
