[QGIS-Developer] GSoC 2026 Draft Proposal : JSON Handling Toolkit for the QGIS Processing Framework
Nyall Dawson
nyall.dawson at gmail.com
Mon Mar 16 22:59:54 PDT 2026
On Tue, 17 Mar 2026 at 15:52, Sionigdha Sadhukhan via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hello,
> I’ve prepared a draft of my GSoC proposal for improving JSON handling in
> the QGIS Processing framework and wanted to share it here and
> recieve your valuable feedback.
> I’ve attached the current version.I tried to incorporate the earlier
> suggestion about looking at JSON handling more broadly in the processing
> framework rather than focusing only on the ogrinfo parameters. If there’s
> anything that seems unclear, unrealistic, or that should be approached
> differently, I would really appreciate any feedback.
Thanks for sending this through Sionigdha!
Just FYI you'll need to submit a QEP before doing any of this work -- see
https://github.com/qgis/QGIS-Enhancement-Proposals. One sticking point that
stood out to me is that you're proposing to implement the new algorithms in
Python. That's explicitly blocked now, we want all new algorithms to be
written in c++ (unless they rely on a specific python library).
Kind regards,
Nyall
Thanks for your time.
> Kind regards,
> Sionigdha.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260317/8a7d7eaf/attachment.htm>
