[QGIS-Developer] Editing CSV files?
Nick Bearman
nick at nickbearman.com
Tue Mar 17 08:19:40 PDT 2026
Thanks for your question Mike.
I hope Alexander's answer helped.
To develop this slightly further, to get consistent options, best
practice would be to save your CSV file to some other format within QGIS
- perhaps as a table without geometry in a geopackage - and then you
will be able to edit it to your heart's content.
Whether this is suitable depends on your wider workflow - and why you
are bringing in a CSV file, which you don't specify.
Good luck!
Best wishes,
Nick.
On 17/03/2026 14:45, Alexander Bruy via QGIS-Developer wrote:
> Hi Mike,
> I think you are loading CSV via Data Source Manager using the
> delimited text data provider, while when you drag-and-drop it the OGR
> provider is used. These providers have different capabilities,
> so this is a normal situation.
> вт, 17 бер. 2026 р. о 14:39 Elstermann, Mike via QGIS-Developer
> <qgis-developer at lists.osgeo.org> пише:
>> Hello everyone,
>> when I load a CSV file (without geometry) via the ‘Data Source Manager’ in QGIS 3 and QGIS 4, I cannot edit it in the attribute table. However, if I drag the CSV file into the project, the attribute table can be edited just as easily as with other datasets.
>> Is this normal? If so, why? Or can this perhaps be adjusted so that the CSV file is always editable?
>> Thanks, mikeE.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Nick Bearman
+44 (0) 7717745715
Please let me know if I can make any adjustments related to disability or neurodivergence to improve how we interact.
Due to my own life/work balance, you may get emails from me outside of normal working hours. Please do not feel any pressure to respond outside of your own working pattern.
