[QGIS-Developer] Reducing the size of our download packages
Nyall Dawson
nyall.dawson at gmail.com
Mon Mar 23 14:45:54 PDT 2026
On Mon, 23 Mar 2026 at 19:20, Tim Sutton via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> Hi all
> Here in the infrastructure management club for QGIS we have been embarking on a plan to slowly divest ourselves of 'big tech'. At the end of last year we switched off cloudflare CDN and implemented our own caching servers. At that time we were doing around 130TB of throughput (including what was being soaked up by Cloudflare). As of last month we did 430TB of throughput without the help of Cloudflare.
> We are trying to optimise costs - that bandwidth alone cost us in the neighbourhood of 500€ per month. To reduce costs we can approach the problem in two way:
> 1. optimise the infrastructure - we (QGIS Devops team) are busy looking into ways to do that...
> 2. reduce the download size...
> We are wondering if the datum shift files could be split out from the main installer and fetched as an optional extra? Or maybe on demand as you need them? We could set up some infrastructure for hosting them, but we would need some help on the application side to implement logic to go and grab shift files that are not locally cached. Is anyone able to help with this?
Well, we already have quite a user friendly existing workflow in place
for advising the user when they should have a grid shift file that
isn't currently installed, and a friendly automated GUI based approach
for doing the download and install.
So IMO we could rip out all the shift files from the installer and
fallback to this for everyone. The only downside would be that it
relies on internet access, and the download would happen once per user
(as opposed to once per organisation if they're bundled).
<sarcastic> Or we just embrace the 2026 view of analysis slop[1] and
stop caring if results are out by ~50m or have any relation to
real-world locations, and rip out the whole proj grid handling logic.
No one seems to care about accuracy and quality in mapping or coding
anymore anyway. </sarcastic>
Nyall
[1] eg https://mapdesign.icaci.org/tag/365daysofmaps/
> Regards
> Tim
> Tim Sutton
> Kartoza Cofounder
> Tim is a member of the QGIS Project Steering Committee
> T : +27(0) 87 809 2702 E : tim at kartoza.com W : kartoza.com
> This email and any attachments are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you
> have received this email in error, please notify the sender immediately and delete it from your system. Unauthorised use, disclosure, or copying
> of the contents is prohibited.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
