[QGIS-Developer] Reduced compatibility with old PosgreSQL/PostGIS databases in v. 4.0.0
Even Rouault even.rouault at spatialys.com
Tue Mar 31 05:54:58 PDT 2026
Carlo,
you're conflating two different things:
- PostgreSQL & PostGIS version support in GDAL.  It might still semi
work for you with dropped supported version by chance/accident.
- PostgreSQL & PostGIS version support in QGIS PostgreSQL provider.
Looking quickly at git log, I don't see anything explicit abut dropping
them. I suppose that support for those older versions broke by accident
or wasn't explicitly mentionned.
In any case those ancient versions aren't supported, have likely unfixed
security issues, and it would be hard for us to test against them.
So use older QGIS versions if you really need to stick with your ancient
PostgreSQL & PostGIS version. There's hardly no chance you can convince
us (at least me for the code I'm responsible of) to bring back support
for them
Even
Le 31/03/2026 à 14:44, Carlo A. Bertelli (Charta s.r.l.) via
QGIS-Developer a écrit :
> I understand that GDAL declares
>     Starting with GDAL 3.9, only PostgreSQL >= 9 and PostGIS >= 2 are
>     supported.
> but version 3.44 still can open layers from a v. 8.4 database and
> PostGIS 1.5.
> Now version 4 does not open layers from this database.
> GDAL v. 3.12.3 per se can open these layers, ogrinfo works well,
> ogr2ogr lets me upload data from files to the same database.
> What happened with the new version? I cannot even change parameters
> per table. Is there a solution for this?
> Unfortunately I cannot change the database nor upgrade it, even if I
> would like very much.
> c
> Carlo A. Bertelli
>    Charta servizi e sistemi per il territorio e la storia ambientale srl
>           Dipendenze del palazzo Doria,
>           vc. alla Chiesa della Maddalena 9/2 16124 Genova (Italy)
>           tel./fax +39(0)10 2475439  +39 0108566195 mobile:+39 393 1590711
>    e-mail: bertelli at chartasrl.eu http://www.chartasrl.eu
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260331/52c9985f/attachment.htm>
More information about the QGIS-Developer mailing list
