[QGIS-Developer] Reduced compatibility with old PosgreSQL/PostGIS databases in v. 4.0.0
Carlo A. Bertelli (Charta s.r.l.) carlo.bertelli at gmail.com
Tue Mar 31 13:00:13 PDT 2026
Thanks to everyone for replying so quickly to this problem.
I totally agree with you about the necessity to upgrade PostgreSQL and I
think it's not a good idea to risk adding bugs to a foundation library as
GDAL.
Anyway, I tried version 3.12.3 and it supports reading from a table and
writing to it without problems. But something changed at least on version
4.0.0 for MacOS.
While the DBManager recognized the table structure, the datasource browser
doesn't and complains:
> Error retrieving fields information for uri: bname='mydb' host=d
> b.myclientshost.com port=5432 user='mypooruser' sslmode=disable
> checkPrimaryKeyUnicity='O' table="oneschema". "mypolytable"
when browsing fields.
Maybe it has something to do with *uri: *bname which obviously means *uri:
dbname* but the typo would break something if it is used in the code.
This is the PostGIS error I get when retrieving this layer:
2026-03-31T21:39:29     WARNING    Erroneous query: SELECT
> has_table_privilege('"oneschema".
> "mypolytable"','SELECT'),pg_is_in_recovery(),current_schema()
> ,has_any_column_privilege('"oneschema".
> "mypolytable"','INSERT'),has_table_privilege('"oneschema".
> "mypolytable"','DELETE'),has_any_column_privilege('"oneschema".
> "mypolytable"','UPDATE'),'f' returned 7 [ERROR: function
> pg_is_in_recovery() does not exist
>              LINE 1: ...vilege('"oneschema".
> "mypolytable"','SELECT'),pg_is_in_r...
>              HINT: No function matches the given name and argument types.
> You might need to add explicit type casts.
> 2026-03-31T21:39:29     WARNING    Unable to determine table access
> privileges for the "oneschema". "mypolytable" relation.
>              The error message from the database was:
>              ERROR: function pg_is_in_recovery() does not exist
>              SQL: SELECT has_table_privilege('"oneschema".
> 2026-03-31T21:46:13     WARNING    Erroneous query: SELECT
> "mypolytable"','UPDATE'),has_column_privilege('"oneschema".
> "mypolytable"','GEOMETRY','UPDATE') returned 7 [ERROR: function
> 2026-03-31T21:46:13     WARNING    Unable to determine table access
while getting the same data by gdalinfo does not need any special
privilege. I should be able to understand what this repeated error means on
the SQL side, but it seems a complete nonsense to me. I'm sure someone
would detect the reason for it.
Is there a way to mitigate it? I was trying to use a virtual ogr file to
handle misbehaving columns; I could convert some specific table to
Spatialite, but I think solving my problem could be useful to someone else.
Thanks in advance for any hint provided.
c
On Tue, Mar 31, 2026 at 8:26 PM Régis Haubourg via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> 9.1 has reached end of life 10 years ago!
> I'm with Even here. A Postgres server out of maintenance period must be
> considered insecure and outdated and must totally be upgraded anyway.
> Cheer, Régis
> On 31/03/2026 18:14, Stefanos Natsis via QGIS-Developer wrote:
> > One breaking change I'm aware of in QGIS 4 is that we've used the
> > `CREATE TABLE IF NOT EXISTS` idiom for the `qgis_projects` table (for
> > storing projects in the database) which was introduced in PostgreSQL 9.1
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260331/e21d8494/attachment-0001.htm>
More information about the QGIS-Developer mailing list
