[QGIS-Developer] Floating an idea: ban AI based contributed from non-core developers?
Even Rouault even.rouault at spatialys.com
Tue Mar 31 18:28:47 PDT 2026
Nyall,
As often with that topic, I'm undecided about the best course of action.
For the sake of the discussion, let me play a bit the devil advocate so
we have counter points to consider:
- restricting AI tool use to core contributors will make the process of
becoming core contributor harder. Core contributors would be able to
improve their capabilities further (questionable claim in terms of
quality. But in quantity&speed, definitely), which will make it harder
to grow new core contributors. There's a high chance the new generation
learning coding today will not be able to produce any working code
without such tools (like I'm 100% dependent on Valgrind to write working
non-trivial C++ code).
- besides the issue with new comers to the project, we most certainly
have regular experienced contributors who haven't the status of core
contributor, probably because nobody thought about proposing them (btw,
I've no idea how to determine who is a core contributor and who
isn't...  is there a public list somewhere ?). Why would they be
discriminated further?
- I would say that we should restrict your proposal even further: "only
core contributors are allowed to use AI tools, only in the areas where
they (feel they) are experts  ", possibly relaxed with "or for
contributions involving non-production code (e.g. CI scripts (*),
etc.)". If I use a AI tool in a part of QGIS I've never touched, there's
a high risk I will produce low quality code with it.
- There's an increased risk that non-core contributors would still use
AI tools, but without telling us. Naive ones will be easily caught;
smarter ones will go under our detection radar. But is there a
difference between good/non-perfect/bad code written with or without AI
assistance that still passes CI and human review...? At the PR unitary
level, I'd say none. The issue is more the about the increased volume of
bad contributions with AI help that can saturate our review bandwidth.
- Side point: I'm wondering if the nature of the tool would make a
difference. I haven't personally used AI tools that can operate on a
whole code base (Claude code and the like), only chat tools that can
work/produce limited code fragments. I'd suspect the former are the ones
where you can vibe code an entire feature, whereas with chatty ones, you
need to iterate much more and thus have hopefully more critical eye. On
the other hand, maybe tools that operate at the whole code base level
can have a better global view... Likely none of those approaches is
fundamentally better than the other one. Different drawbacks.
To me it looks like we are caught in an arm race we haven't decided to
be part of but can't easily escape.  So, half joking/half serious, let's
use AI tools to detect bad AI output ?!? (ignoring who has used the
tool). I suspect that AI companies would love such outcome...  Or maybe,
until the AI industry collapses entirely, let's temporarily go back to
sending patches on 3.5 inches floppy disks (1.44 MB ones only, not
extended 2.88 MB ones)  through (post) mail.
At the same time I'm writing this, I'm caught in a situation where I'm
questioning the need for a GDAL PR whose quality isn't necessarily bad
(I haven't done the in-depth analysis), but which is likely not strictly
needed (premature optimization/complication), and would have most
certainly not be submitted at all if AI didn't exist. From my experience
with recent AI assisted PRs to GDAL, that's actually the main problem.
Too much code being written in a too short period of time, that will
make us totally dependent on AI tools to be able to contribute further.
So, all in all, not opposed to your proposal, but we need to be careful
how we phrase it to not scare away non-core contributors or increase
unwanted discrimination.
Even
(*) Because I've just played this afternoon with Gemini chat to come up
with some python clang AST code to write custom code checkers to verify
project specific code rules (like pairing Reference() in constructor and
Release() in destructor). The result is .. well... AI typical. Mostly
sort of works after a couple iterations, but definitely not something
that would be of the quality that clang-tidy or similar serious tools
would expect. But good enough for the purpose it was created. Or at
least I was tricked into believing it was good enough...
http://www.spatialys.com
More information about the QGIS-Developer mailing list
