[QGIS-Developer] (no subject)
Sionigdha Sadhukhan
snigdha.lee75 at gmail.com
Wed May 13 01:02:21 PDT 2026
Hi Valentin,
Firstly sorry for the late reply, I was finishing up my end semester exams
and couldnt reply until now.
Thank you for the kind words, it genuinely helps. And you are right that
the work was not wasted. I did come out of this understanding the QGIS
codebase and contribution process a lot better than when I started, and
that is valuable regardless of the outcome.
The plugin idea caught my attention. I am curious to know more about what
you had in mind, would it essentially be the same JSON toolkit algorithms
but packaged as a plugin rather than contributed directly to core? I am
asking because I want to understand whether this would be more of a
personal learning project or something that could eventually feed back into
the QGIS ecosystem in some way. Either way I am open to it, just want to
understand the direction better before diving in.
Best regards , Sionigdha
On Wed, 6 May 2026 at 03:54, Valentin Buira <valentin.buira at gmail.com>
wrote:
> Hi Sionigdha,
> I am sorry your proposal could not make it.
> I would like to thank you as well for the time you invested in your
> proposal. And reassures you that it's not all lost, the design you
> did is there and could be used as a basis for future work
> I would also like to encourage you to pursue in the QGIS ecosystem. I
> was not accepted either in GSoC at the time, but here I am. I hope the
> community can offer you a way to get involved in QGIS project.
> Since you are not binded to a GSoC proposal anymore, maybe having a
> prototype in the shape of a QGIS plugin would be doable ?
> Cheers,
> Valentin
> Le jeu. 30 avr. 2026 à 20:40, Sionigdha Sadhukhan via QGIS-Developer
> <qgis-developer at lists.osgeo.org> a écrit :
> > Thank you all for your time.Thanks for guiding through.Specially Nyall
> ,Even and Valentine!
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260513/5a774188/attachment.htm>
