[QGIS-Developer] qgis4 segfaults with qt6 6.11.0, ok with 6.10.2
Greg Troxel
gdt at lexort.com
Wed May 13 05:23:06 PDT 2026
Richard Duivenvoorde <rdmailings at duif.net> writes:
> I've succesfully compiled and ran QGIS4 with Qt 6.9.2 and 6.10.2 as those are available in Debian Testing.
4.0.0 and 4.0.2+18 both work with 6.10.2, except that they fail to find
the authentication provider. I suspect the authentication provider
problem is about some qt6 part not being in pkgsrc yet.
> I think I've heard there were some issues with opening older project
> files in QGIS4, but as Qt6.10 is working that is probably not the
> issue here?
4.0.2+18/6.10.2 will open a project file and act normally while
4.0.2+18/6.11.0 crashes on the same file.
Starting without a project file is ok.
Other complicated qt6-using programs work with 6.11.0 (on
NetBSD-current), according to others.
> Can you create an issue maybe, preferably with a gdb trace on a debug
> build? Hopefully core devs have a clue then?
I see from Andrea that osgeo4w has 4.0.2 with Qt 6.11.0, but I wonder
does it work :-) ?
surely that uses some different implementations than on POSIX, so
while it's a very helpful data point, I'm not sure what I can
conclude.
I should mention that I'm using X11 (which I've been using since I
upgraded from X10!), given the "wayland is the answer, what was the
question" problems in some corners of the GNU/Linux world.
Has anyone run qgis 4 with 6.11.x on POSIX with X11?
Overnight, pkgsrc got qt6 6.11.1, changelog "bugfixes". I am updating
and will rebuild all and see how it goes. If still not ok, I'll flip to
debug builds and build qt6 and qgis again, so gdb can get better
backtraces, and file an issue.
