[QGIS-Developer] SAGA GIS plugin maintenance
Rainer Hurling
rhurlin at gwdg.de
Sat May 23 02:03:32 PDT 2026
Hi Jürgen,
Am 21.05.26 um 19:36 schrieb Jürgen E. Fischer via QGIS-Developer:
> Hi Andrea,
> On Thu, 21. May 2026 at 18:27:02 +0200, Andrea Giudiceandrea via QGIS-Developer wrote:
>> Il 21/05/2026 13:57, Jürgen E. Fischer via QGIS-Developer ha scritto:
>>> Nyall only needed to remove his repo to make it disappear completely. There
>>> apparently wasn't a single fork from contributors - not one.
>> actually there are various forks of the "Processing Saga NextGen Provider"
>> repository still alive on GitHub [1].
>> AFAIK, mine [2] is up to date to Nyall's latest commit. I've also added the
>> zipped file of the latest release of the plugin that was available on the
>> plugins' server, version 1.1.0 [3].
> um, odd. apologies. I looked for "qgis-processing-saga-nextgen" on github
> and only got 2 results - rhurlin's (original?) repo with a 7 year old commit
> being the latest and a docker image.
Just for clarification: My version isn't the “original,” but a fork from
Victor Olaya's repo (volaya@). I have absolutely no idea why GitHub
doesn't show this (“Fork from volaya/qgis-processing-saga-nextgen”). My
patch in this fork was necessary in 2019 so that the plugin could use
newer SAGA versions. After that, I never needed it again and lost track
of it. Unfortunately, it also doesn’t seem to be updatable against
original repo (pull ...).
Rainer
> But I missed that rhurlin's repo has more current forks, which I would have
> expected to see in the search too.
> Jürgen
