[QGIS-Developer] Request from QGIS docs writers
Ismail Sunni
imajimatika at gmail.com
Tue May 26 00:07:35 PDT 2026
Hi Selma,
For 3D data, perhaps you check this list from Martin Dobias:
https://github.com/wonder-sk/3d-spatial-data *in case you haven't seen it
before.
Best regards
On Mon, May 25, 2026 at 5:17 PM Selma Vidimlic via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi devs,
> Hope you're all doing well! We're reaching out from the documentation team
> with a few requests.
> As we work on documenting various features, we've run into challenges
> finding good test data, particularly for 3D, point clouds, and specific
> database formats. If any of you have sample data you could share, or know
> of reliable sources where we could find suitable datasets, that would be a
> huge help. And if you're aware, when developing things, that a format you
> use is specific or hard to find online, please consider sending us your own
> test data directly, that would be especially valuable.
> We're also putting together content for the QGIS Open Day (QOD) series,
> and 3D features are high on our list. If you have suggestions for
> interesting data sources that would showcase these features well, please
> share them with us.
> A couple of other things we'd like to flag:
> **"Needs documentation" label**: It would mean a lot if you could keep an
> eye on this label in the dev repository and action it when relevant.
> Staying on top of it helps us keep documentation timely and accurate.
> Sometimes we receive issue tickets in our repo and when working on them, we
> might discover related PRs in the dev repo, or we might find new UI
> elements without a corresponding issue ticket in our repo, then we need to
> dig through the development repository. This process can take some time or
> even confuse us as writers.
> **Feature descriptions & use cases**: Whenever you have a spare moment,
> even a brief description of a feature or a real-world use case goes a long
> way in helping us document things properly.
> We know you're busy, and we truly appreciate any time and input you can
> spare.
> Thanks so much,
> Selma Vidimlic Husic
> *QGIS Documentation writer*
> *E:* selma at kartoza.com * W:* kartoza.com
> *This email and any attachments are confidential and intended solely for
> the use of the individual or entity to whom they are addressed. If you *
> *have received this email in error, please notify the sender immediately
> and delete it from your system. Unauthorised use, disclosure, or copying *
> *of the contents is prohibited.*
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Ismail Sunni
Software Engineer
ismailsunni.id
ismailsunni.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260526/96640e34/attachment-0001.htm>
