[QGIS-Developer] QGIS 4: PostgreSQL layer properties 'Information from provider' is not displayed correctly
Rainer Hurling rhurlin at gwdg.de
Sun May 31 10:58:56 PDT 2026
I was unable to attach a screenshot to a GitHub issue. Therefore, I am
describing the following issue here in the list, as it is difficult to
describe the error without an image.
In QGIS 4, in released versions up to 4.0.3 as well as in today's devel
branch, the “Information from provider” section in the properties of
PostgreSQL layers is displayed incorrectly. This happens in the browser
and also with loaded layers.
Instead of the expected information under Privileges or Spatial Index, a
list of dots is displayed. Each dot in the list contains exactly one
character. All characters in a list appear to be SQL commands or
parameters? The attached screenshot shows a section where the display
error can be seen.
This occurs on Windows 10, 11, and FreeBSD. In QGIS 3, the properties of
PostgreSQL layers are displayed correctly.
Best regards,
Rainer
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260531/4b71b4b5/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
