[QGIS-Developer] Confirmation Request: Oracle JDK 21.0.12 Dependency on QGIS
Marco Serusi administration at qgis.org
Tue Nov 3 01:10:00 PST 2026
Hello Amit,
I have noticed that Santos has reached out to our security team on
multiple occasions, and I was wondering if you'd be so kind as to help us
reach out to some of your colleagues who could help us improve our project
and security.
As I'm sure you know, QGIS is a free, open-source software, built and run
by volunteers in their spare time.  This has several advantages since it
means all of our information, code, and indeed the software itself is
freely available to anyone, including companies like Santos. On the
flip side, it also means the project is entirely dependent on donations to
pay its bills and to fund improvements that the volunteers are not able to
do themselves.
As such, we'd appreciate it if you could help us find the right people
within Santos who could release funds to support the project. From the
multiple emails we have received from you and your colleagues, it is clear
that security is an important topic for Santos and that Santos is using
this free software to generate profits; therefore, it would seem fair if
the company gave back to the project as well.
With regard to your question, the volunteers from the security team will
respond when time allows. In the meantime, please consider checking the
many QGIS online communities that are available or the free documentation
and resources. Keep in mind that, as an open-source project, all of our
code is publicly viewable, and everything we do is also public, so it
should be fairly easy to locate the information you require.
Kind regards
On Tue, Nov 3, 2026 at 2:39 AM 'Sisodia, Amit (Amit)' via security <
security at qgis.org> wrote:
> Hi team ,
> We are currently reviewing the upgrade to Oracle JDK 21.0.12 as part of
> our security remediation activities and would like to confirm whether QGIS
> has any dependency on this JDK version.
> Could you please advise on the following:
>    - Does QGIS require or depend on Oracle JDK 21.0.12 for any
>    functionality, plugins, or services?
>    - Is Oracle JDK 21.0.12 a supported version for the currently deployed
>    QGIS version 3.22.5?
>    - Are there any known compatibility issues, limitations, or
>    recommendations regarding the use of Oracle JDK 21.0.12 with QGIS?
>    - If QGIS or any associated components include or utilize their own
>    Java Runtime Environment (JRE/JDK), please confirm whether upgrading the
>    system-installed JDK would have any impact on the application or its
>    functionality.
>    - Are there any QGIS plugins, extensions, or integrations that may be
>    affected by an Oracle JDK upgrade?
> Your guidance will help us proceed with our security remediation and
> upgrade activities accordingly.
> Thanks & regards
> Amit Sisodia
> TCS - Exp Application Support team
> Amit.Sisodia at contractor.santos.com
*Marco Serusi*
*Administrative Assistant - QGIS*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20261103/3a317722/attachment.htm>
More information about the QGIS-Developer mailing list
