[QGIS-Developer] [Qgis-psc] Grant report: Restore the print layout HTML item for QGIS 4
Tim Sutton tim at qgis.org
Sun Nov 15 12:08:16 PST 2026
Amazing work, thank you so much Nyall!
Regards
Tim
On Fri, Nov 13, 2026 at 4:35 AM Nyall Dawson via QGIS-PSC <
qgis-psc at lists.osgeo.org> wrote:
> Hi PSC,
> I'm happy to report that following the grant "Restore the print layout
> HTML item for QGIS 4"
> (https://github.com/qgis/QGIS-Enhancement-Proposals/pull/377), the
> print layout HTML item has now been resurrected for QGIS 4.4!
> This was a heavy undertaking, involving many different parts. The
> upstream removal of the QtWebkit support and replacement by the
> less-featured (but more modern and secure) webengine framework
> completely removed the API we were relying on for rendering the HTML
> print layout item.
> No direct replacement API was available for rendering webengine
> content in high quality, vector formats. To work around this, I've
> implemented a complicated approach that uses webengine's print
> capabilities to export vectorised HTML content to a PDF file, and then
> the PDF4QT library to render this into the layout HTML item.
> Via this approach I've been able to resurrect almost all the
> functionality that the item had under QGIS 3, including support for
> user stylesheets, and injection of atlas feature json into the HTML.
> Additionally, I took the opportunity to fix a long-standing
> performance issue relating to the HTML item. In QGIS 3, the HTML
> content would always be loaded and rendered immediately, in the main
> thread, when creating the item. This also occurred whenever a QGIS
> project was loaded that contained a HTML item, resulting in very slow
> load times for these projects! Furthermore, all the HTML rendering was
> always done on the GUI thread, so navigating and interacting with
> layouts containing HTML content was slow and would result in many QGIS
> pauses.
> Now, all the loading and rendering is done asynchronously. The HTML
> fetching and rendering will only happen when required (no longer at
> project load time!), and now happens in a background thread so that
> the layout designer always remains responsive to work with.
> That said, there remains some regressions which users should be aware
> of when compared with the HTML item support in QGIS 3:
> - The webengine backend uses its own independent networking library,
> which is not integrated in any way with the networking library used by
> the rest of QGIS. Accordingly, the HTML item will ignore the proxy,
> SSL, cache, user agent, authentication and other QGIS network
> settings. Requests won't be shown in the QGIS Network logger panel
> either. QGIS administrators will need to be aware of this and adjust
> their network's firewall settings accordingly.
> - While the HTML content is always rendered as high-quality vectors,
> text from the HTML will always be converted to paths. This looks
> identical, but means that text from the HTML item in  PDF or SVG
> exported layouts won't be selectable, searchable, or editable. (It's
> possible that this limitation may be fixable in follow-up work)
> - HTML content will render slightly larger than in QGIS 3 (around 10%
> larger). This is a feature, not a bug! The original webkit library
> incorrectly sized the HTML content, as reported in
> https://github.com/qgis/QGIS/issues/19901. Now, the font and css sizes
> from the HTML content will be an exact match for font and other sizes
> for non-HTML layout items. Users may need to adjust their HTML or CSS
> to adjust for this sizing difference when loading older projects into
> QGIS 4.
> Thanks to the QGIS project and all donors for funding this work and
> restoring this valuable capability!
> (The final part of this work is currently waiting review at
> https://github.com/qgis/QGIS/pull/68161)
> Nyall
> QGIS-PSC mailing list
> QGIS-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
*Tim Sutton*
QGIS Project Steering Committee
tim at qgis.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20261115/b89d374f/attachment.htm>
More information about the QGIS-Developer mailing list
