[QGIS-Developer] Fwd: GRASS in QGIS
Vaclav Petras
wenzeslaus at gmail.com
Wed Oct 21 15:12:01 PDT 2026
On Sun, 11 Oct 2026 at 07:30, Andreas Neumann via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> and would avoid some of the issues we have with security scanners who
> seem to dislike the GRASS file naming patterns like r.out.png.exe - we
> have many false positives of security scanners about these file naming
> patterns.
Hi Andreas,
GRASS is also hitting the r.out.png issue. I don't know if there is a
solution for it besides renaming to something like r.out.image
(multi-format + similar rename for all similar tools) and renaming with
underscores to r_out_png (so changing the convention completely). I did
name the function with underscores in a new Python API (grass.tools), so
there is that as a precedence.
Since you mentioned the one problematic tool I have in my mind as well,
have you encountered other issues like that or r.out.png is the one? If it
is isolated just to r.out.png, then finding a safer name for the tool is
probably the cheapest route we can take.
Vaclav
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20261021/c5e1e296/attachment.htm>
