[QGIS-it-user] Fwd: QFIELD e INPUT, osservazioni generali
Luigi Pirelli
luipir a gmail.com
Sab 6 Apr 2019 13:31:05 PDT
FYI
---------- Forwarded message ---------
From: Saber Razmjooei <saber.razmjooei a lutraconsulting.co.uk>
Date: Sat, 6 Apr 2019 at 21:36
Subject: Re: [QGIS-it-user] QFIELD e INPUT, osservazioni generali
To: Luigi Pirelli <luipir a gmail.com>
Thanks Luigi for forwarding me the email.
Some very useful information, bugs and features which we will be definitely
consider.
I'm not subscribed to the Italian mailing list. But it will be good if the
author publishes the comparison on a blog post (ideally in English which
I'm happy to help, for a wider audience).
A couple of points to note:
- Input is purely based on QGIS quick library. So it's easier to port to
other platforms, e.g windows or iOS.
-Input is aimed for those who can operate Google map. So, the interface and
list of functionality is intentionally limited e.g. there is no node editor
or QGI message logs. Comparable app is probably Fulcrum.
-Input has its built in functionality to synchronise data over cloud. So
multiple people can edit the same project. Transferring data back and forth
and collaborative work is very common in field data collection. Maybe the
author should review that too.
Hope all is settled now after the hectic HF and you are having a more
relaxing (well deserved) time!
Regards
Sabet
On Sat, 6 Apr 2019, 20:18 Luigi Pirelli, <luipir a gmail.com> wrote:
> Questo puó interessarvi
> ---------- Forwarded message ----------
> From: *alper78* <alsper78 a gmail.com>
> Date: Saturday, 6 April 2019
> Subject: [QGIS-it-user] QFIELD e INPUT, osservazioni generali
> To: qgis-it-user a lists.osgeo.org
> Ho fatto alcune prove con queste app per la mappatura di sentieri penso di
> farne anche per il censimento di alberi. A mio parere sono già a buon punto
> e utilizzabili (soprattutto QFIELD) per lavori di rilevamento (almeno per
> gli elementi puntuali).
> Versione QFIELD provata: 1.0.3
> Versione INPUT provata: 0.2.7
> Ho provato ad usare vettoriali e raster in formato geopackage e funzionano
> bene.
> Come uso mi sembra che QFIELD sia più veloce a rispondere mentre con INPUT
> a
> volte ho difficoltà a far scorrere la lista dei campi (ma è un
> comportamento
> che potrebbe dipendere dal dispositivo usato).
> INPUT ha il vantaggio di poter registrare tracce gps. Invece con QFIELD mi
> salvo i punti iniziale e finale di ogni tratta mentre tengo un'altra app in
> background che registra tutto il percorso, poi a casa/ufficio con QGIS
> spezzo la traccia dove serve.
> QFIELD ha il vantaggio di poter "ricordare" il valore inserito nei campi,
> cioè se spunto la casella apposita a destra del campo, quando inserirò un
> nuovo elemento troverò già quel campo con il valore inserito in precedenza.
> Molto comodo ad esempio in un censimento di alberi: se c'è un filare di
> piante della stessa specie, stessa età e potati alla stessa altezza metto
> la
> spunta sulle voci che rimangono fisse e non devo inserirle ogni volta. In
> INPUT non mi sembra di vedere questa possibilità. (Questa è la
> caratteristica principale che al momento mi fa preferire QFIELD rispetto a
> INPUT)
> *Visibilità dei layer*: in QFIELD tenendo premuto su un layer compare
> l'opzione per visualizzare o nascondere un layer. In INPUT non ho trovato
> questa possibilità ma si possono creare più temi in QGIS da scegliere poi
> in
> INPUT; può essere uno svantaggio se uno non sa a priori quali layer vorrà
> vedere o nascondere o un vantaggio se ci sono molti layer e si possono
> prevedere le combinazioni che verranno usate.
> *Fotocamera*: purtroppo entrambe le app NON usano il controllo nativo della
> fotocamera ma una versione semplificata che non consente (o io non ho
> trovato il modo) alcuni controlli come zoom, luminosità, flash. In QFIELD
> c'è un'opzione per usare la fotocamera nativa ma con l'avviso che è
> instablie con le ultime versioni di Android ed infatti con il controllo
> nativo riesco a scattare le foto ma va in crash quando tento di salvarle.
> *Attribute forms* (ho provato quelli che mi sembrano più utili):
> Ottima e funzionante in entrambe le app la possibilità di usare la "mappa
> valori" che consente di mostrare un menù a tendina dove poter scegliere il
> valore da inserire nel campo.
> Funziona in entrambe anche la possibilità di nascondere un campo.
> Allegato/Foto: ok per entrambe le app ma come già detto con controlli
> semplificati per la fotocamera.
> Data/ora: ho provato ad usare il valore predefinito now() per avere subito
> impostato l'orario ma funziona solo in QFIELD. Però in INPUT si può
> aggiungere l'orario attuale con un tocco sull'icona a destra del campo.
> Casella di controllo: funziona in QFILED, non in INPUT.
> Purtroppo in entrambe le app NON hanno effetto i forms "Valori univoci" e
> "Relazione valore" che secondo me sarebbero molto utili.
> "Valori univoci" (con la spunta modificabile) permetterebbe, mentre si sta
> digitando un valore, di far comparire ed eventualmente selezionare i valori
> già inseriti con le stesse iniziali. Molto utile quando ci sono valori che
> si ripetono non i sequenza (se si ripetono in sequenza si può usare la
> spunta di QFIELD per "ricordare" il valore). Ad esempio i nomi scentifici
> di
> specie in un censimento di piante: quando un nome è già presente poi basta
> inserire le prime due o tre lettere per far comparire il nome
> corrispondente
> e questo oltre a velocizzare il lavoro abbassa anche la probabilità di
> inserire nomi sbagliati.
> "Relazione valore": mostrerebbe un menù a tendina i cui valori
> selezionabili
> dipendono da un altro campo e questo impedirebbe che vengano assegnati per
> sbaglio attributi incompatibili. Ad esempio una tratta di sentiero di
> tipologia "Pista forestale" non può avere come difficoltà "EEA
> (Escursionisti Esperti Attrezzati)".
> (PS: potrebbe essere che invece i due forms suddetti funzionino ma io non
> sono stato capace di impostarli correttamente, quindi sarei grato a chi
> volesse provare e verificare se è veramente un problema delle app)
> *Stabilità*
> Non posso pronunciarmi su INPUT perché l'ho usato troppo poco. Invece ho
> provato QFIELD per più di 24 ore (ovviamente non consecutive) e l'unico
> problema l'ho notato quando si scattano le foto: a volte quando si salva la
> foto, l'app si blocca e mi tocca chiuderla e riaprirla; ma è una cosa rara:
> su circa 250 foto fatte da QFIELD mi è successo 4 o 5 volte.
> Alessandro Perego
> http://www.alspergis.altervista.org
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html
> QGIS-it-user mailing list
> QGIS-it-user a lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-it-user
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> * Hire me: http://goo.gl/BYRQKg
Un allegato HTML è stato rimosso...
URL: <http://lists.osgeo.org/pipermail/qgis-it-user/attachments/20190406/1b586558/attachment.html>
Maggiori informazioni sulla lista
QGIS-it-user
