[QGIS-it-user] Errore Python: Impossibile caricare il plugin 'processing' Vedi il log dei messaggi (Errore Python) per maggiori dettagli.
Studio Multiservice s.s. studio.multiservice.mantova a gmail.com
Lun 3 Feb 2020 10:59:42 PST
Buona sera a tutt*
dopo aggiornamento tramite osgeo su win10 64bit, all'avvio QGIS 3.4 o 3.10
LTR non mi carica il plugin processing e trovo il seguente log
Avete un suggerimento?
grazie
2020-02-03T19:52:55     WARNING
warning:C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qgis_proj_helper.py:8:
DeprecationWarning: QgsCoordinateReferenceSystem constructor is deprecated
              CRS_3857 = QgsCoordinateReferenceSystem(3857)
             traceback: File "", line 1, in
              File "C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line
354, in startPlugin
              if not _startPlugin(packageName):
334, in _startPlugin
              plugins[packageName] = package.classFactory(iface)
              File
"C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\__init__.py",
line 34, in classFactory
              from .quick_map_services import QuickMapServices
744, in _import
              mod = _builtin_import(name, globals, locals, fromlist, level)
              File "", line 983, in _find_and_load
              File "", line 967, in _find_and_load_unlocked
              File "", line 677, in _load_unlocked
              File "", line 728, in exec_module
              File "", line 219, in _call_with_frames_removed
              File
"C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\quick_map_services.py",
line 40, in
              from .qgis_map_helpers import add_layer_to_map
744, in _import
              File
"C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qgis_map_helpers.py",
line 17, in
              from .py_tiled_layer.tilelayer import TileLayer
744, in _import
              File
"C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\py_tiled_layer\tilelayer.py",
line 36, in
              from ..qgis_proj_helper import ProjectionHelper
744, in _import
              File
"C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qgis_proj_helper.py",
line 7, in
              class ProjectionHelper:
              File
line 8, in ProjectionHelper
warning:C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\py_tiled_layer\tilelayer.py:64:
354, in startPlugin
              File
744, in _import
              File
line 40, in
744, in _import
              File
line 17, in
744, in _import
              File
line 62, in
              class TileLayer(QgsPluginLayer):
              File
line 64, in TileLayer
warning:C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\rb_result_renderer.py:35:
              self.srs_wgs84 = QgsCoordinateReferenceSystem(4326)
359, in startPlugin
              plugins[packageName].initGui()
              File
line 121, in initGui
              self.init_server_panel()
              File
line 311, in init_server_panel
              self.server_toolbox = QmsServiceToolbox(self.iface)
              File
"C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qms_service_toolbox.py",
line 135, in __init__
              self.extent_renderer = RubberBandResultRenderer()
              File
"C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\rb_result_renderer.py",
line 35, in __init__
2020-02-03T19:52:56     WARNING
warning:C:\OSGEO4~1\apps\Python37\lib\site-packages\urllib3\connectionpool.py:1004:
InsecureRequestWarning: Unverified HTTPS request is being made to host '
qms.nextgis.com'. Adding certificate verification is strongly advised. See:
https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
              InsecureRequestWarning,
359, in startPlugin
              File
              File
              File
line 155, in __init__
              self.show_news()
              File
line 160, in show_news
              qms_news = client.get_news()
              File
"C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qms_external_api_python\api\api_abstract.py",
line 64, in get_news
              response = get(url, verify=False)
              File
"C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\api.py", line 75, in
get
              return request('get', url, params=params, **kwargs)
              File
"C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\api.py", line 60, in
request
              return session.request(method=method, url=url, **kwargs)
              File
"C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\sessions.py", line
533, in request
              resp = self.send(prep, **send_kwargs)
              File
646, in send
              r = adapter.send(request, **kwargs)
              File
"C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\adapters.py", line
449, in send
              timeout=timeout
              File
"C:\OSGEO4~1\apps\Python37\lib\site-packages\urllib3\connectionpool.py",
line 672, in urlopen
              chunked=chunked,
              File
line 376, in _make_request
              self._validate_conn(conn)
              File
line 1004, in _validate_conn
Alberto
Il giorno lun 3 feb 2020 alle ore 18:53 Paolo Cavallini <
cavallini a faunalia.it> ha scritto:
> capito, in effetti strano che non ci sia fra le opzioni dell'alg nativo,
> puoi aprire una feature request per cortesia?
> grazie
> Il 03/02/20 09:20, Luca Puglisi ha scritto:
> > Buffer di una linea con estremi piatti, diciamo tronchi, anziche'
> > stondati (tipo endcap=flat)
> > grazie, ciao
> > Luca
> > Il 03/02/2020 08:40, Paolo Cavallini ha scritto:
> >> in che senso squadrati?
> >> saluti.
> >> Il 03/02/20 08:28, Luca Puglisi ha scritto:
> >>> Nell'occasione semplicemente quello per fare buffer, avendo la
> >>> necessita' di farli squadrati--
> >> Paolo Cavallini - www.faunalia.eu
> >> QGIS.ORG Chair:
> >> http://planet.qgis.org/planet/user/28/tag/qgis%20board/
> >> _______________________________________________
> >> QGIS-it-user mailing list
> >> QGIS-it-user a lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/qgis-it-user
> QGIS.ORG Chair:
Un allegato HTML รจ stato rimosso...
URL: <http://lists.osgeo.org/pipermail/qgis-it-user/attachments/20200203/7d571c3a/attachment-0001.html>
Maggiori informazioni sulla lista QGIS-it-user
