[QGIS-it-user] Errore Python: Impossibile caricare il plugin 'processing' Vedi il log dei messaggi (Errore Python) per maggiori dettagli.
Stefano Campus skampus a gmail.com
Lun 3 Feb 2020 11:59:05 PST
Dalle prime righe di errore sembra che non gli piaccia il plugin Quick map
services.
Prova a disabilitarlo, o a disinstallarlo o a creare un profilo pulito.
Il lun 3 feb 2020, 20:00 Studio Multiservice s.s. <
studio.multiservice.mantova a gmail.com> ha scritto:
> Buona sera a tutt*
> dopo aggiornamento tramite osgeo su win10 64bit, all'avvio QGIS 3.4 o 3.10
> LTR non mi carica il plugin processing e trovo il seguente log
> Avete un suggerimento?
> grazie
> 2020-02-03T19:52:55     WARNING    warning:C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qgis_proj_helper.py:8:
> DeprecationWarning: QgsCoordinateReferenceSystem constructor is deprecated
>               CRS_3857 = QgsCoordinateReferenceSystem(3857)
>              traceback: File "", line 1, in
>               File "C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line
> 354, in startPlugin
>               if not _startPlugin(packageName):
> 334, in _startPlugin
>               plugins[packageName] = package.classFactory(iface)
>               File
> "C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\__init__.py",
> line 34, in classFactory
>               from .quick_map_services import QuickMapServices
> 744, in _import
>               mod = _builtin_import(name, globals, locals, fromlist, level)
>               File "", line 983, in _find_and_load
>               File "", line 967, in _find_and_load_unlocked
>               File "", line 677, in _load_unlocked
>               File "", line 728, in exec_module
>               File "", line 219, in _call_with_frames_removed
>               File
> "C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\quick_map_services.py",
> line 40, in
>               from .qgis_map_helpers import add_layer_to_map
> 744, in _import
>               File
> "C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qgis_map_helpers.py",
> line 17, in
>               from .py_tiled_layer.tilelayer import TileLayer
> 744, in _import
>               File
> "C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\py_tiled_layer\tilelayer.py",
> line 36, in
>               from ..qgis_proj_helper import ProjectionHelper
> 744, in _import
>               File
> "C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qgis_proj_helper.py",
> line 7, in
>               class ProjectionHelper:
>               File
> line 8, in ProjectionHelper
> 2020-02-03T19:52:55     WARNING    warning:C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\py_tiled_layer\tilelayer.py:64:
> 354, in startPlugin
>               File
> 744, in _import
>               File
> line 40, in
> 744, in _import
>               File
> line 17, in
> 744, in _import
>               File
> line 62, in
>               class TileLayer(QgsPluginLayer):
>               File
> line 64, in TileLayer
> 2020-02-03T19:52:55     WARNING    warning:C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\rb_result_renderer.py:35:
>               self.srs_wgs84 = QgsCoordinateReferenceSystem(4326)
> 359, in startPlugin
>               plugins[packageName].initGui()
>               File
> line 121, in initGui
>               self.init_server_panel()
>               File
> line 311, in init_server_panel
>               self.server_toolbox = QmsServiceToolbox(self.iface)
>               File
> "C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qms_service_toolbox.py",
> line 135, in __init__
>               self.extent_renderer = RubberBandResultRenderer()
>               File
> "C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\rb_result_renderer.py",
> line 35, in __init__
> 2020-02-03T19:52:56     WARNING    warning:C:\OSGEO4~1\apps\Python37\lib\site-packages\urllib3\connectionpool.py:1004:
> InsecureRequestWarning: Unverified HTTPS request is being made to host '
> qms.nextgis.com'. Adding certificate verification is strongly advised.
> See:
> https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
>               InsecureRequestWarning,
> 359, in startPlugin
>               File
>               File
>               File
> line 155, in __init__
>               self.show_news()
>               File
> line 160, in show_news
>               qms_news = client.get_news()
>               File
> "C:/Users/user/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\quick_map_services\qms_external_api_python\api\api_abstract.py",
> line 64, in get_news
>               response = get(url, verify=False)
>               File
> "C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\api.py", line 75, in
> get
>               return request('get', url, params=params, **kwargs)
>               File
> "C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\api.py", line 60, in
> request
>               return session.request(method=method, url=url, **kwargs)
>               File
> "C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\sessions.py", line
> 533, in request
>               resp = self.send(prep, **send_kwargs)
>               File
> 646, in send
>               r = adapter.send(request, **kwargs)
>               File
> "C:\OSGEO4~1\apps\Python37\lib\site-packages\requests\adapters.py", line
> 449, in send
>               timeout=timeout
>               File
> "C:\OSGEO4~1\apps\Python37\lib\site-packages\urllib3\connectionpool.py",
> line 672, in urlopen
>               chunked=chunked,
>               File
> line 376, in _make_request
>               self._validate_conn(conn)
>               File
> line 1004, in _validate_conn
> Alberto
> Il giorno lun 3 feb 2020 alle ore 18:53 Paolo Cavallini <
> cavallini a faunalia.it> ha scritto:
>> capito, in effetti strano che non ci sia fra le opzioni dell'alg nativo,
>> puoi aprire una feature request per cortesia?
>> grazie
>> Il 03/02/20 09:20, Luca Puglisi ha scritto:
>> > Buffer di una linea con estremi piatti, diciamo tronchi, anziche'
>> > stondati (tipo endcap=flat)
>> > grazie, ciao
>> > Luca
>> > Il 03/02/2020 08:40, Paolo Cavallini ha scritto:
>> >> in che senso squadrati?
>> >> saluti.
>> >> Il 03/02/20 08:28, Luca Puglisi ha scritto:
>> >>> Nell'occasione semplicemente quello per fare buffer, avendo la
>> >>> necessita' di farli squadrati--
>> >> Paolo Cavallini - www.faunalia.eu
>> >> QGIS.ORG Chair:
>> >> http://planet.qgis.org/planet/user/28/tag/qgis%20board/
>> >> _______________________________________________
>> >> QGIS-it-user mailing list
>> >> QGIS-it-user a lists.osgeo.org
>> >> https://lists.osgeo.org/mailman/listinfo/qgis-it-user
>> QGIS.ORG Chair:
Un allegato HTML รจ stato rimosso...
URL: <http://lists.osgeo.org/pipermail/qgis-it-user/attachments/20200203/487875aa/attachment-0001.html>
Maggiori informazioni sulla lista QGIS-it-user
