[QGIS-it-user] problemi con plugin Select_by_relationship
antonio valanzano
anvalanz a gmail.com
Mar 21 Gen 2020 06:59:33 PST
Sto cercando di utilizzare il plugin ma una volta definita la relazione 1-N
(tra una tabella geometrica ed una non geometrica) non vengono selezionati
i record della tabella geometrica una volta selezionati uno o più record
della tabealla non geometrica.
Ho provato a disinstallare il plugin ma mi compare il seguente messaggio di
errore:
An error has occurred while executing Python code:
RuntimeError: wrapped C/C++ object of type CheckableComboBox has been
deleted
File "C:/Users/anvalanz/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\SelectByRelationship\select_by_relationship_plugin.py",
line 212, in toggleButton
self.comboRelations.setEnabled(toggled)
RuntimeError: wrapped C/C++ object of type CheckableComboBox has been deleted
Python version: 3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:06:47) [MSC
v.1914 32 bit (Intel)]
QGIS version: 3.4.14-Madeira Madeira, c92881c294
Python Path:
- C:/OSGeo4W/apps/qgis-ltr/./python
- C:/Users/anvalanz/AppData/Roaming/QGIS/QGIS3\profiles\default/python
- C:/OSGeo4W/apps/qgis-ltr/./python/plugins
- C:\OSGeo4W\apps\gdal2\pymod3\scripts
- C:\OSGeo4W\apps\gdal2\pymod3\lib\site-packages
- C:\OSGeo4W\apps\Python37
- C:\OSGeo4W\apps\Python37\Scripts
- C:\OSGeo4W\bin\python37.zip
- C:\OSGeo4W\apps\Python37\DLLs
- C:\OSGeo4W\apps\Python37\lib
- C:\OSGeo4W\bin
- C:\OSGeo4W\apps\Python37\lib\site-packages
- C:\OSGeo4W\apps\Python37\lib\site-packages\win32
- C:\OSGeo4W\apps\Python37\lib\site-packages\win32\lib
- C:\OSGeo4W\apps\Python37\lib\site-packages\Pythonwin
C:/Users/anvalanz/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\go2streetview
C:\Users\anvalanz\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\go2streetview\res
C:\Users\anvalanz\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\mmqgis/forms
- C:/DATI_NEW/Progetti_QGIS3
La finestra di errore si chiude solo dopo aver forzato più volte la
chiusura.
A qualcuno è già capitato ?
Antonio Valanzano
Un allegato HTML è stato rimosso...
URL: <http://lists.osgeo.org/pipermail/qgis-it-user/attachments/20200121/5b967b11/attachment.html>
Maggiori informazioni sulla lista
QGIS-it-user
