[Qgis-psc] [Qgis-developer] CI testing for OSX
Nyall Dawson
nyall.dawson at gmail.com
Fri Aug 14 20:45:12 PDT 2015
On 15 Aug 2015 13:17, "Larry Shaffer" <larrys at dakotacarto.com> wrote:
> Hi Nyall, all,
> On Thu, Aug 13, 2015 at 11:31 PM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
>> On 13 August 2015 at 04:32, Tim Sutton <tim at qgis.org> wrote:
>> > Awesome stuff Nyall - can you give any notes on what specifically you
had to do to enable OS X testing?
>> Not much really... all the ground work was already in place and were
>> just waiting on Travis to open up multi OS builds again. Whoever setup
>> the homebrew install package (Larry?) made it super easy to install
>> the dependencies, and we already had 99% of the tests passing without
>> error on OSX. Michael Kirk had also already given this a shot so I was
>> able to borrow parts of his attempts which also helped a lot.
> Yes, I set up the QGIS Homebrew formulae in the osgeo/osgeo4mac tap.
> For example, to set up a dev environ on Mac:
https://github.com/OSGeo/homebrew-osgeo4mac/wiki/Developing-on-QGIS-using-OSGeo4Mac
> I haven't had time recently to update the work there, so some of the
notes may be outdated.
Thanks Larry, this made it really easy to implement this.
I'm wondering- is there a way to prevent the installation of
postgres/postgis when installing the dependencies? It slows the build down
a lot and conflicts with the existing preinstalled postgis available on
Travis.
Nyall
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
>> Nyall
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20150815/d642442c/attachment.html>
More information about the Qgis-psc
