[Qgis-psc] Proposal that QGIS.ORG will become a member of the OpenDesign Alliance
Andreas Neumann
a.neumann at carto.net
Thu Dec 17 07:57:48 PST 2015
Hi all,
Jürgen is currently investigating whether libdxfrw can be a Teigha
alternative, resp. what is missing in libdxfrw to fulfill our requirements.
The whole situation with dxf/dwg libraries is a bit messy. Lots of
abandoned projects and not a lot of documentation around. Thanks for all
who helped investigating the issue. It really isn't easy to find out
which project forked from which other project and is used by which
software. Also which project has which license restrictions and still
alive ...
If libdxfrw is a viable alternative to Teigha I am of course for using
this library instead of Teigha.
Seems like libdxfrw is currently our best bet as a GPL compatible
DXF/DWG library.
Let's wait for Jürgens feedback.
Andreas
On 17.12.2015 15:35, Saber Razmjooei wrote:
> Hi all,
> My workflow so far for dealing with DWG files have been:
> - Using Teigha File Converter to convert DWG files to DXF (a binary tool distributed for free by OpenDesign to convert DWG/DXF formats)
> - In QGIS, using DXF2Shape to convert dxf files to vector consumable in QGIS
> The problem with Dxf2Shape is that the converted vector file does not include symbology, text and other info on the spec document sent earlier by Andreas.
> After Sandro's email, I have downloaded and compiled the code for libdxfrw. Using the dwg2dxf tool from libdxfrw, I then converted my 2015 DWG CAD file to dxf.
> I had some problems opening the resultant DXF in TrueView (AutoCAD file viewer) but managed to successfully use DXF2SHAPE to convert the file and read it in QGIS.
> To summarise, in my opinion, it will be best to:
> - embed libdxfrw library to convert DWGs to DXF behind the scene. If necessary, improve the library to handle complex DWG files.
> - improve DXF2Shape plugin...or if needed re-develop a new tool to handle DXF files
> Hope that helps.
> Regards,
> Saber
> -----Original Message-----
> From: Qgis-psc [mailto:qgis-psc-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
> Sent: 16 December 2015 16:46
> To: Andreas Neumann; vincent.ml at oslandia.com; qgis-psc at lists.osgeo.org
> Subject: Re: [Qgis-psc] Proposal that QGIS.ORG will become a member of the OpenDesign Alliance
> UPDATE: it looks like libdxfrw (used by LibreCAD) has been made GPL2+:
> https://sourceforge.net/p/libdxfrw/code/ci/master/tree/
> It's documented to be able to read up to 2015 version of DWG files.
> Thread here:
> https://sourceforge.net/p/libdxfrw/discussion/general/thread/6d9d288c/
> --strk;
> On Wed, Dec 16, 2015 at 02:24:10PM +0100, Sandro Santilli wrote:
>> On Wed, Dec 16, 2015 at 01:54:38PM +0100, Andreas Neumann wrote:
>>> Hi Strk,
>>> So why aren't FreeCAD, LibreCAD, Blender and Inkscape using
>>> LibreDWG? As far as I understand, it is because some of their other
>>> components/libraries are GPLv2 only and thus they can't mix? I can't
>>> claim that I understand all of these licensing issues. But
>>> apparently, for some reasons the majority of the LibreGraphics
>>> software cannot use LibreDWG. This is what the say at their
>>> websites:
>>> http://freecadweb.org/wiki/?title=Licence#GPL2.2FGPL3.2FOCTLP_incomp
>>> atibility
>>> https://en.wikipedia.org/wiki/LibreCAD#GPLv3_vs_GPLv2_controversy
>> So it looks, but those articles don't state clearly which dependencies
>> are GPL2-only so I cannot easily check if that's still the case.
>>> Apparently LibreCAD created their own library, which is available at
>>> http://sourceforge.net/projects/libdxfrw/
>> And they made it GPL2-only. That's a bad move really :(
>>> About the funding drive: this funding drive is about the Free
>>> Software Foundation (FSF) in general, not for the LibreDWG project,
>>> unfortunately. You can find the same funding drive on
>>> http://www.gnu.org/ and other GNU websites. Unfortunately, FSF,
>>> doesn't treat LibreDWG as a priority project.
>> Oops, you're right. Sorry for the confusion.
>>> So basically, GRASS is the only piece of software using LibreDWG -
>>> according to
>>> https://libreplanet.org/wiki/Group:LibreDWG#Who_uses_it.3F
>>> because the information about LibreCAD is outdated.
>> That seems to be the case, yes.
>> --strk;
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
> by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
> that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
> such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
More information about the Qgis-psc
