[Qgis-psc] Bug fixing effort from Jürgen
Neumann, Andreas
a.neumann at carto.net
Wed Jul 22 06:38:13 PDT 2015
Below is the list of what Jürgen did during his paid bug fixing:
#10632: Cannot rename connection name (PostGIS, WMS, WFS) in other case
#11317: PostGIS views not handled correctly
#11545: Categorized/graduated symbology does not work for a virtual
field computed using a joined column
#11687: Selected encoding disappears when duplicating layer
#11755: Real precision (Shapefile)
#11997: QGIS hangs importing a shapefile into spatialite
#12325: Integer fields converted to text when exported from Spatialite
#12368: DXF export: unfilled polygons are not rendered
#12393: GPS information panel, dialogue "Satellite "crashes QGIS 2.8
(regression)
#12421: QGIS form : range with decimal > rounding by saving project ?
#12432: WMTS extent of TileMatrixSet as extent of layer
#12434: Wrong order in table
#12461: Unable to commit date changes to MSSQL table in 2.8.1 Wien
#12477: removing programmatically generated field while attribute table
is open crashes QGIS
#12478: Estimated extent of PostGIS layers with mixed case names
#12484: QGIS Server: invalid list of of layers in "LayerDrawingOrder"
when using embedded groups/layers
#12488: Impossible to merge features in a point shapefile
#12505: QBrowser's Set Layer CRS action is disabled
#12507: Browser OWS connections issues in 2.8.1/master
#12648: When editing a CSV (added as geometryless table) newly added
records disappear after saving
#12654: Remove geographical operations on table layers
#12690: Snapping do not work for new features after save edits on oracle
spatial layer
#12719: QGIS crashes when 'Hide deprecated' enabled from Select datum
transformations dialog
#12730: "Check Geometry Validity" produces incorrect result
#12733: Layer order list corrupted if a layer reference can't be
resolved
#12785: Adding spatialite layer to project data gets corrupted(?)
#12796: Export Spatialite point layer to CSV fails on Geometry AS_XY
#12799: QgsFeatureRequest iterator using filterRect (spatial index) lose
some feature with invalid geometries which have one segment in common.
#12841: Save as shapefile fails on PostGIS layer with joined MSSQL Table
#12863: Using localized QGIS attribute table feature counts in title bar
is broken
#12886: delete part has no effect on single geometries
#12909: Can't edit new features without
"ChangeAttributeValue"/"ChangeGeometry" capability
#12957: Feature count doesn't show correct values for PostGIS layers
after deletinge features
#12959: No visual feedback when moving geometries with the node tool
#12985: Shapefile: The length of real type field is reduced by 1 every
save
#12996: Regression - Wrong default values on feature attributes edit
form
#13001: bigint geometries empty
#13005: QgsOracleFeatureIterator: returns all features if layer has no
index
#13011: CRS not ok between switching between projects with different crs
(unreported) crash on geometryless wfs features
(unreported) edit widget: show date if null allowed
(unreported) fix crash on add part
(unreported) render: consider 3d after merge
(unreported) processing: fix installation of saga 2.1.3 descriptions
(unreported) handle ogr sublayers with colon
(unreported) browser: add i18n
(unreported) fix some crash on invalid layers
(unreported) wms provider: recover configurable FEATURE_COUNT
+ backports to 2.8
+ after the release: bugfixing of the testsuite including making them
+ work on
windows and backporting to 2.10 -
http://dash.orfeo-toolbox.org/index.php?project=QGIS [1] is now mostly
green, opposed to
http://dash.orfeo-toolbox.org/index.php?project=QGIS&date=2015-06-26
[2].
Nyall also worked on that - not sure about how large the part of each
one of us is.
Andreas
Links:
[1] http://dash.orfeo-toolbox.org/index.php?project=QGIS
[2]
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20150722/5ef8fb88/attachment.html>
More information about the Qgis-psc
