[Qgis-psc] Processing test framework
    Alexander Bruy
    alexander.bruy at gmail.com
    Wed Feb  3 10:13:31 PST 2016
I'm available to update User Guide with text about creating new tests
2016-02-03 20:05 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 03/02/2016 17:55, Matthias Kuhn ha scritto:
>> Manually verify that the result corresponds with what you would expect
>> from it. If it does not or if there's an error in the log, fix the
>> algorithm and restart. If everything is ok, go to the history, right
>> click the entry and generate the test. Copy the generated text to the
>> file testdata/algorithm_tests.yaml in the abovementioned folder.
>> Commit/push and make a pull request, so we can see if travis is happy
>> with the change as well.
> Yes, I guessed something like this.
> My point is: let's make it **very** obvious to anyone, with blog posts,
> step by step howtos, etc. to make as easy as humanly possible. Every
> little grain of sand will translate in less contributors.
> Of course I'm available as an early tester for the procedure, time
> permitting.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
Alexander Bruy
More information about the Qgis-psc
