[Qgis-psc] Draft announcement re 3.0
Andreas Neumann a.neumann at carto.net
Sun Feb 7 22:25:41 PST 2016
Hi Tim,
Thank you for the draft!
One issue I have is the term "master branch" - which perhaps could be
made clearer, less ambiguous.
Is there only one "master branch" at any time or will there be two
parallel "master branches" - a 2.x one and a 3.x one? Normally, I would
assume that there can be only one master branch at any given time - e.g.
2x will stay master branch until 2.16 and then 3.0 would be the master
branch. Or can there be two parallel master branches?
One statement i don't like is "only for 3.x: not knowing when that will
ever release or" --> could we rather say "only for 3.x: not knowing when
this will release or" (take out the word "ever")
I assume that we think that 3.x will happen, but we don't know when. The
current wording seems to imply that the PSC has doubts if 3.x will ever
happen - which I don't think is the case. But since this "o-tone
Jürgen", I don't know if you want to change this ...
Andreas
On 07.02.2016 22:56, Tim Sutton wrote:
> Hi PSC
> I have written up a draft announcement about the 3.0 plan. I am
> including a complete draft below.. Please let me know if you have
> comments, corrections, additions to this DRAFT so that I can post it
> and then advertise it more broadly.
> COPY BEGINS
> QGIS 3.0 plans
> Ok so quick spoiler here: there is no QGIS 3.0 ready yet, nor will
> there be a QGIS 3.0 for some time. This article provides a bit more
> detail on the plans for QGIS 3.0. A few weeks ago I wrote about some
> of the considerations for the 3.0 release, so you may want to read
> that first
> <http://blog.qgis.org/2016/01/17/help-us-to-plan-for-qgis-3-0/> before
> continuing with this article as I do not cover the same ground here.
> A *lot* of consideration has gone into deciding what the approach will
> be for the development of QGIS 3.0. Unfortunately the first PSC
> vote regarding which proposal to follow was a split
> <https://www.loomio.org/d/5MCdPwoL/vote-to-approve-the-process-for-qgis-3-0> decision
> (4 for, 3 against, 1 abstention and 1 suggestion for an alternative in
> the discussion). During our PSC meeting this week we re-tabled the
> topic and eventually agreed on Jürgen Fischer's proposal (Jürgen is a
> QGIS PSC Member and the QGIS Release Manager) by a much more unanimous
> margin of 8 for, 1 neutral and 1 absent. Jürgen's proposal is largely
> similar to the Proposal 2 described in my previous posting
> <http://blog.qgis.org/2016/01/17/help-us-to-plan-for-qgis-3-0/>. I
> want to make some special notes here about our discussion and
> subsequent decision which will hopefully help to clarify the thinking
> behind our decision for other interested observers.  First let me lay
> out Jürgen's plan in his own words:
> "My preferred approach would still be:
>   * Do a Qt5/PyQt5/Python3 branch in parallel, actually work on it
>     until it's ready, make it master and release it as 3.0
>   * Meantime keep working on master (2.x) and keep releasing them
>     every 4 months as usual
> Everyone can work on the branch (s)he wants (or is hired to), but
> needs to consider if (s)he want to do it (or spend funds on):
>   * only for 2.x: knowing that it will be released soon; but might
>     become unusable because platforms drop support for stuff it
>     depends on sooner or later
>   * only for 3.x: not knowing when that will ever release or
>   * for both: knowing that work needs to be done twice.
>   * People adding features to the master branch will be responsible to
>     ensure that their work gets merged to 3.0 branch.
> As PSC we should maintain the environment for people to do something
> for QGIS - but we cannot tell them to - so we don't have resources we
> can actually plan with and that means we can either release something
> when the big thing is ready or what we have in fixed intervals." -
> Jürgen Fischer
> What follows are some further details and clarifications to our
> preferred approach:
> *Why do parallel development?*
> Parallel development of 3.0 maintaining our master branch with 2.x
> code in it has advantages and disadvantages. First the advantages:
>   * If we encounter major technical difficulties / release blockers in
>     the 3.0 branch, it will not impact on our normal 3 monthly release
>     cycle.
>   * Our binary build systems (Linux, Windows and OSX binaries) will be
>     unaffected until 3.0 is ready.
>   * It is very likely that building 3.0 binaries on different
>     platforms is going to have difficulties for each platform. For
>     example OSGEO4W has no Python3 and Qt5 packages yet. Someone needs
>     to see to the creation of the required package as a separate
>     exercise from the actuals development of a version of QGIS that
>     will take advantage of these updated libraries. We don't yes know
>     what problems may be in countered in preparing these.
>   * "Don't break what already works": we have a working and relatively
>     stable master branch and we don't want to do a 'cowboy stunt' and
>     break it. We prefer to wait until the 3.0 branch is mature, has
>     passing tests and is known to work well before merging it into
>     master and treating it as our 'best we currently have' master branch.
> Of course nothing in life is completely easy, there are also some
> disadvantages*:*
>   * Some developers may feel that running two mainstream branches is
>     dilution of effort. To counter this, our public recommendation is
>     that after 2.16 comes out, all QGIS contributors are *strongly
>     encouraged* to provide their patches against the 3.0 branch.
>     Any features applied to the master branch is *not guaranteed* to
>     be part of the 3.0 release.
>   * Regular merging of master to the 3.0 branch may prove more and
>     more difficult over time as the two branches diverge more. Again
>     we will strongly encourage that developers submitting new features
>     after the 2.16 release do so against the 3.0 branch.
>   * 3.0 branch won't have auto build system for nightly binaries in
>     the beginning. Since we expect that the initial branch of 3.0 will
>     break these anyway, Having a separate branch is actually an
>     advantage here as it will give binary packages some time to get
>     their build systems up to speed.
> *The schedule will not be fixed:*
> One thing that we want to make really clear (and was a key point in
> our many discussions) is that there will be no fixed release date for
> QGIS version 3.0. There are several reasons for this:
>   * As a steering committee, we can only set the QGIS ship pointing in
>     a given direction, our power to actually make work happen is
>     extremely limited. This is because we are a community made up
>     largely of volunteer developers or developers working on a
>     commission basis for third party clients. We have no say in how
>     these contributors spend their time.
>   * We do not yet know which (if any) major technical issues will be
>     encountered during the development of 3.0. Any such issues could
>     very well delay the roll our of QGIS 3.0.
> Instead our plan is to make the 2.16 release and then effectively move
> all developer effort to the 3.0 branch as best we can (through close
> liaison with our developer community).
> *Looking forward to 3.0*
> Personally I am very much looking forward to the release of QGIS 3.0 -
> it represents another huge milestone in our project, it affords us a
> great opportunity to get rid of a lot of cruft out of our code base
> and API's and it will arm us with a set of modern, new libraries that
> will see us through the next several years. Rock on QGIS 3.0!
> timsutton
> QGIS PSC Chairman
> COPY ENDS
> Tim Sutton
> Visit http://kartoza.com to find out about open source:
> * Desktop GIS programming services
> * Geospatial web development
> * GIS Training
> * Consulting Services
> Skype: timlinux Irc: timlinux on #qgis at freenode.net
> <http://freenode.net>
> Tim is a member of the QGIS Project Steering Committee
> Kartoza is a merger between Linfiniti and Afrispatial
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160208/6c9f5e17/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160208/6c9f5e17/attachment.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160208/6c9f5e17/attachment-0001.png>
More information about the Qgis-psc mailing list
