[Qgis-psc] Bugfixing for QGIS 2.16
Matthias Kuhn
matthias at opengis.ch
Mon Jul 11 06:14:09 PDT 2016
Dear PSC,
here is a list of what has been done as part of the sponsored bugfixing
period.
I didn't focus on a particular area of the code nor did I count each
hour spent on bugfixing.
Besides this, I spent as usual time on maintaining the continuous
integration platform (travis) and pull request reviewing/merging and
followed up a couple of tickets which I was unable to solve in the end.
Thanks a lot for sponsoring this effort and have fun with a stable QGIS 2.16
Matthias
Improve QgsMapLayerRegistry stability
https://hub.qgis.org/issues/14822
Processing: Difference algorithm: don't ignore invalid geometries by default
https://hub.qgis.org/issues/9297
Fixed some Python 3 compatibility issues
Work on re-enabling osx tests (merged after 2.16 release)
API documentation
startup.py is executed twice
https://hub.qgis.org/issues/15189
UX fixes
* Attribute table: always show sequential column header numbers
* Relation Reference Widget: Only enable form button when a feature is set
* Show feature id in attribute table tooltip
* Initial widget focus in credential dialog
* Default timeout for message bar items
* "Add button" state in postgis source select dialog
Install missing header files
Crash on exit
https://hub.qgis.org/issues/15088
Network cache directory
https://hub.qgis.org/issues/15111
https://hub.qgis.org/issues/14990
Feature form hidden behind main window on Windows
https://hub.qgis.org/issues/15103
Offline editing: Respect relative paths
Offline editing, changed attributes end up in wrong feature
https://hub.qgis.org/issues/14727
Offline editing: Don't crash with raster layers
https://hub.qgis.org/issues/14848
Relation form grows infinitely
https://hub.qgis.org/issues/14977
Fix crash when loading style in layer properties
Fix crash when closing docked attribute table
https://hub.qgis.org/issues/14909
https://hub.qgis.org/issues/15018
Fix default-misconfigured gpsbabel path
https://hub.qgis.org/issues/14866
Show correct feature count with rule that requires geometry
https://hub.qgis.org/issues/14758
Fix crash when using 2.5D renderer with incompatible layer
https://hub.qgis.org/issues/14814
More information about the Qgis-psc
