[Qgis-psc] Bugfixing for QGIS 2.16
Tim Sutton tim at kartoza.com
Mon Jul 11 09:08:22 PDT 2016
Hi Matthias
Thanks so much - I will add your notes to the changelog!
Regards
Tim
> On 11 Jul 2016, at 8:14 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Dear PSC,
> here is a list of what has been done as part of the sponsored bugfixing
> period.
> I didn't focus on a particular area of the code nor did I count each
> hour spent on bugfixing.
> Besides this, I spent as usual time on maintaining the continuous
> integration platform (travis) and pull request reviewing/merging and
> followed up a couple of tickets which I was unable to solve in the end.
> Thanks a lot for sponsoring this effort and have fun with a stable QGIS 2.16
> Matthias
> Improve QgsMapLayerRegistry stability
>  https://hub.qgis.org/issues/14822
> Processing: Difference algorithm: don't ignore invalid geometries by default
>  https://hub.qgis.org/issues/9297
> Fixed some Python 3 compatibility issues
> Work on re-enabling osx tests (merged after 2.16 release)
> API documentation
> startup.py is executed twice
>  https://hub.qgis.org/issues/15189
> UX fixes
> * Attribute table: always show sequential column header numbers
> * Relation Reference Widget: Only enable form button when a feature is set
> * Show feature id in attribute table tooltip
> * Initial widget focus in credential dialog
> * Default timeout for message bar items
> * "Add button" state in postgis source select dialog
> Install missing header files
> Crash on exit
>  https://hub.qgis.org/issues/15088
> Network cache directory
>  https://hub.qgis.org/issues/15111
>  https://hub.qgis.org/issues/14990
> Feature form hidden behind main window on Windows
>  https://hub.qgis.org/issues/15103
> Offline editing: Respect relative paths
> Offline editing, changed attributes end up in wrong feature
>  https://hub.qgis.org/issues/14727
> Offline editing: Don't crash with raster layers
>  https://hub.qgis.org/issues/14848
> Relation form grows infinitely
>  https://hub.qgis.org/issues/14977
> Fix crash when loading style in layer properties
> Fix crash when closing docked attribute table
>  https://hub.qgis.org/issues/14909
>  https://hub.qgis.org/issues/15018
> Fix default-misconfigured gpsbabel path
>  https://hub.qgis.org/issues/14866
> Show correct feature count with rule that requires geometry
>  https://hub.qgis.org/issues/14758
> Fix crash when using 2.5D renderer with incompatible layer
>  https://hub.qgis.org/issues/14814
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160711/d0ae6ca1/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160711/d0ae6ca1/attachment.jpg>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20160711/d0ae6ca1/attachment.sig>
More information about the Qgis-psc mailing list
