[Qgis-psc] docs + website move to osgeo6?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Jul 15 10:50:04 PDT 2016
+1
mapserver.org static files also were moved to osgeo6. I've ran into
problems though as that newer virtual machine has much more tight
security, so you may have to jump through some hoops (file tickets) to
get your rsync scripts to run as they did before, unless you are lucky
to have sudo on that machine :)
Safe virtual travelling, ha.
-jeff
On 2016-07-15 12:21 PM, Richard Duivenvoorde wrote:
> Hi,
> qgis1 (the hub server which we serve debian/ubuntu repo's, qgis-website
> and qgis-documentation from is full).
> I asked the easiest solution for that on SAC, see
> https://lists.osgeo.org/pipermail/sac/2016-July/007238.html
> and it seems to move our static files to osgeo6:
> https://wiki.osgeo.org/wiki/Osgeo6
> So: should we do that? I can start with the docs + website (those are
> rsynce during every build, so moveing some apache conf's to there and
> change the rsync scripts should work....)
> Regards,
More information about the Qgis-psc
