[Qgis-psc] QGIS 2.16 sponsored bugfixing report
    Even Rouault
    even.rouault at spatialys.com
    Tue Jun 21 12:25:02 PDT 2016
Here are the tickets I've dealt with during my allocated time for QGIS 2.16 bug fixing.
Severe/High :
- https://hub.qgis.org/issues/15006: Crashes in standalone browser
- https://hub.qgis.org/issues/14876: WFS client broken in QGIS master
- https://hub.qgis.org/issues/13762: Error accessing external WMS server -- WMS provider: Cannot calculate extent
- https://hub.qgis.org/issues/14927: Attribute table sorting problem with qgis-rel-dev (2.14.X regression)
- https://hub.qgis.org/issues/15064: QGIS crashes on OGR layers with wkbUnknown25D, wkbUnknownM/Z/ZM layer geometry type
- https://hub.qgis.org/issues/14844: Oblique Mercator projection hanging when rendering map
- https://hub.qgis.org/issues/15047: ASSERT failure in QVector<T>::at: "index out of range" in qgis_attributetabletest (TestQgsAttributeTable)
- https://hub.qgis.org/issues/15087: Crash when deleting the last segment of a compoundcurve
Normal
- https://hub.qgis.org/issues/14965: wfs provider copies features when zoomin in and out
- https://hub.qgis.org/issues/14928: WMS request without BBOX
- https://hub.qgis.org/issues/14999: Spatialite provider does not support alphanumeric primary keys (backport in 2.14)
- http://hub.qgis.org/issues/15061: Cannot add WFS layer
- https://hub.qgis.org/issues/15065: Failed detection of geometry type in some conditions
- https://hub.qgis.org/issues/15066: OGR: Sublayers detected sometimes when not relevant (Polygon/CurvePolygon)
- https://hub.qgis.org/issues/15067: DXF export creates invalid file
- https://hub.qgis.org/issues/15081: Impossible to clear geometry of feature from a shapefile
- unreported [Geometry] Fix various issues related to Wkb/Wkt import
Other:
- https://hub.qgis.org/issues/14981: Import of Shapefile to Geopackage-Database in DB-Manager fails (analysis)
- https://hub.qgis.org/issues/15011: Browser panel is unusable (bisection & analysis)
- https://hub.qgis.org/issues/14909: regression: QGIS crashes when closing docked attribute table (analysis)
- https://hub.qgis.org/issues/13353: QGIS and gdal 2.0.0 (closed: no further action needed)
- https://hub.qgis.org/issues/15053: WMS with EPSG:31255 is shifted (datum=hermannskogel) (analysis. probably outdated proj.4 version)
Best regards,
Even
http://www.spatialys.com
More information about the Qgis-psc
