[Qgis-psc] Selection of successful QGIS grant applications
DelazJ
delazj at gmail.com
Wed Apr 26 05:10:56 PDT 2017
Hi PSC and all,
Thanks Tim for the counting. And congratulations to "winners".
Thanks Andreas to remind us that Documentation has a (unfortunately unused)
budget. Is it still 5 k€? It could be nice if we find opportunities to
spend it. So, here are some ideas:
1/ I recall that during the first round of Grant applications there was a
couple of proposals regarding PyQGIS Cookbook update. Once QGIS 3 API is
stable, we could potentially fund one of them, if the applicants are still
interested.
2/ Also, i have in mind some improvements that would benefit to the
documentation, that I've reported here, and there or have discussed briefly
with some doc teammates:
- update training manual
- a good and efficient search tool in the manuals: the results of the
search box at the top of documentation pages do not seem pertinent; it
might be a matter of configuration or sphinx version (which Richard should
upgrade in Essen, if all goes fine). Still, that's currently a weakness of
our doc infrastructure imho.
- a clean and readable pdf manual: I still believe that in low connection
environment, this could be of interest and use for people.
3/ add to qgis website statistics of translated website/doc/desktop as done
by the Portuguese user group at http://www.qgis.pt/traducao.html These
information are currently "hidden" behind Transifex login. I think that
showing every body the level of QGIS translation into their language could
lead to some sane competition between communities and translators work will
be more visible and advertised (and hopefully, attract new translators?)
4/ a new design of qgis website and documentation: I was expecting a grant
application for the desktop design (or did I misunderstand some discussions
in ML?) but I wonder if QGIS3 and the new logo are not the opportunity to
give new colorful identity to our websites
... other ideas/needs???
That said, beyond finances, it requires someone to be aware and interested
in fixing these issues. Should we make a call? Or.... a QGIS Documentation
Grant application :) ?
Regards,
Harrissou
2017-04-21 11:21 GMT+02:00 Nathan Woodrow <madmanwoo at gmail.com>:
> Hey,
> I think that in the end that is just what can happen. We are doing this
> open for a reason. Having said I would be keen to see if we can fund the
> OS X packages for Larry anyway even if we need to pull some more money.
> Given it's an infrastructure issue and would help the uptake on OS X even
> more, which may lead to more funds, I think it's ok to use money for that
> outside of grants, but I'm not also on the PSC ;)
> Regards,
> Nathan
> On Fri, Apr 21, 2017 at 4:56 PM, Neumann, Andreas <a.neumann at carto.net>
> wrote:
>> Hi Nyall,
>> According to https://docs.google.com/spreadsheets/d/1tHWM0aILCXyGvMj8Y
>> sIxo4ynmJH_wA2VDYVrEs_QLtI/edit#gid=1593575986 if we take out the
>> "Processing Algorithm Documentation", the "Update MacOS CMake Bundling
>> Scripts" still wouldn't make it.
>> However, the PSC could decide to still fund these additional 1.8k €. I
>> would be a +1 on that and think we can afford it. The multi-platform nature
>> of QGIS is a big plus when comparing it with other platforms and we should
>> continue to invest into our multiple platforms - esp. when it comes to such
>> infrastructure work.
>> Personally, I am really surprised and a bit disappointed that "QGIS 3D"
>> was so popular and I was hoping that "Update MacOS CMake Bundling Scripts"
>> would make it in the top proposals. I was thinking that it would be easy to
>> find funds for cool 3D stuff or other cool new features, but not so easy to
>> find funders for infrastructure work or important and less visible
>> under-the-hood improvements. Seems like not all voting members think along
>> these lines that primarily important boring, under-the-hood and
>> infrastructure stuff should be sponsored, and that the "cool" stuff should
>> be funded through other sources. Not that I am against 3D, and certainly
>> not against Martins proposal - I hope that this is clear.
>> Andreas
>> On 2017-04-21 00:28, Nyall Dawson wrote:
>> On 21 April 2017 at 07:47, Tim Sutton <tim at qgis.org> wrote:
>> Hi Larry
>> On 20 Apr 2017, at 7:24 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> Hi Tim and PSC,
>> Is the a reason normal cumulative weighting of the votes was not used
>> instead of the per-level exclusionary approach?
>> Attached are the tally results when done in a cumulative manner, which I
>> think is a fairer representation of one's vote and reflection upon each
>> project's overall importance, when compared to the current method. Note the
>> very different results, though the top projects are still fairly similar.
>> Thanks that makes much better sense - I have updated the spreadsheet
>> summary tab accordingly. As you say the outcome for the top 5 items is the
>> same (though their sequence changes) - I will follow your approach for
>> future grant votes.
>> Fantastic work Tim + PSC, this is all very exciting to see!
>> Inevitable question - if the processing documentation work gets funded
>> through the documentation budget, does that mean the (much needed) OSX
>> packaging work would squeeze in?
>> Nyall
>> Qgis-psc mailing list
>> Qgis-psc at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20170426/03eff7bb/attachment.html>
More information about the Qgis-psc
