[Qgis-psc] QGIS 2.18 bug fixing effort
    Giovanni Manghi
    giovanni.manghi at gmail.com
    Mon May 22 08:14:23 PDT 2017
Unfortunately... hi again.
Definitely NOT a good day for the 2.18.8 update.
I just confirmed this, also was not a problem in 2.18.7
https://issues.qgis.org/issues/16594
WFS crashing QGIS on 2.18.8
cheers
-- G --
On Mon, May 22, 2017 at 4:00 PM, Giovanni Manghi
<giovanni.manghi at gmail.com> wrote:
> Hi Again,
> another regression has hit 2.18.8, this time since 2.18.7
> https://issues.qgis.org/issues/16598
> "Adding PostGIS layers from the browser or DB-Manager crashes QGIS (mini-dump)"
> tested on both Windows and Linux.
> -- G --
> On Mon, May 22, 2017 at 3:34 PM, Giovanni Manghi
>> Hi all,
>> this
>> https://issues.qgis.org/issues/16593
>> has just "entered" the list of regressions (causing crash) in 2.18
>> that were ok on 2.14.
>> cheers!
>> -- G --
>> On Fri, May 5, 2017 at 10:14 AM, Giovanni Manghi
>>> Hi Andreas and Alexander,
>>> the list of regression bugs (excluded the ones affecting ONLY master)
>>> and bugs causing crashes or data corruption is here:
>>> https://docs.google.com/spreadsheets/d/1frZQU8bwGX499WMvtOc6GDIWqEuSv3QHz3zc90TS46Q/edit?usp=sharing
>>> I'm trying to keep it updated as much as I can.
>>> There is a column that specifies if the regression has slip into 2.18
>>> since 2.14, to me that are the worst bugs as 2.18 will become LTR.
>>> Cheers!
>>> -- G --
>>> On Fri, May 5, 2017 at 10:02 AM, Andreas Neumann <andreas at qgis.org> wrote:
>>>> Hi Alex,
>>>> Thank you for your reply.
>>>> I'll cc Giovanni.
>>>> Giovanni - can you please provide Alex a list of processing/analysis related
>>>> bugs/regressions - the most pressing ones?
>>>> Alex: we'll be happy to pay for a couple of hours. We would be interested in
>>>> a regular relationship with core devs who are available to fix the most
>>>> pressing issues prior to every release and potentially also after.
>>>> Can you estimate - how many hours or days you can dedicate to fixing issues?
>>>> I mean within the next 1-2 months and for QGIS 2.18
>>>> I'll add you to our list of core devs who participate in our bug fixing
>>>> effort then -
>>>> https://docs.google.com/spreadsheets/d/1Cdh-6eAmVCdiZIQGMhu_Aqgg09tpxsC40BGXQJtYc54/edit#gid=1281977200
>>>> Thanks,
>>>> Andreas
>>>> On 3 May 2017 at 18:39, Alexander Bruy <alexander.bruy at gmail.com> wrote:
>>>>> Hi Andreas,
>>>>> 2017-05-03 13:10 GMT+03:00 Andreas Neumann <andreas at qgis.org>:
>>>>> > I wonder if you would be interested / would have time - to assist us
>>>>> > with
>>>>> > our QGIS 2.18 bug fixing efforts - esp. with the processing issues?
>>>>> Sure I will be happy to help with this as much as I can.
>>>>> > We would pay some devs for up to 5 days (total 40h per dev) with a fixed
>>>>> > hourly rate of 100 €. Some devs can only contribute a day or two - which
>>>>> > is
>>>>> > also fine.
>>>>> I would like to donate my time to project.
>>>>> Alexander Bruy
>>>> Andreas Neumann
>>>> QGIS.ORG board member (treasurer)
More information about the Qgis-psc
