[Qgis-psc] QGIS 2.18 bug fixing effort
Jürgen E. Fischer jef at norbit.de
Tue May 23 01:11:43 PDT 2017
Hi Paolo,
On Tue, 23. May 2017 at 09:13:23 +0200, Paolo Cavallini wrote:
> Too bad, thanks Giovanni for checking. I think these are serious enough
> to warrant an early release of 2.18.9 when fixed, or removing .8 from
> downloads.
It is already fixed.
> As a side note: only innocuous bugfixes should go into a release branch;
> can we understand what has gone wrong, to prevent it in the future?
It was introduced with a fix for the harmless bug #15510 - rather cosmetic I'd
say, but the fix affects a lot of layer inserts (not only wfs).
It also had QStringLiteral inside, that is not part of Qt4 (hence shouldn't
have been backported to 2.18 as is).  But that only caused problems on trusty
and jessie - other apparently have a newer version of qca that has a macro for
QStringLiteral.  I still had to trigger rebuilds for those - delayed the
announcement a bit.  But it made the window to file tickets before that even
happened larger.
> Is there a serious lack of tests in this area to prevent these problems to go
> unnoticed?
People should test the nightlies - esp. before releases - and not wait for the
new release.  People that install before it's even announced/visible, should
also be able to check the nightlies.  I doubt they just hit the window by
chances, but obviously that could still be the case.
Anyway, that wouldn't have helped in this case either as the offensive fix was
backported on release day.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20170523/73a047e3/attachment.sig>
More information about the Qgis-psc mailing list
