[Qgis-psc] QGIS Server funding
Régis Haubourg regis.haubourg at gmail.com
Thu Nov 16 07:59:19 PST 2017
Hi again,
As discussed in july, we worked on fixing all issues regarding OGC
compliancy with WMS 1.3.0 in QGIS server 3.
Paul Blottiere did great and we reach now a *100% compliancy* on all
testing levels (basic, queryable,  elevation and recommended ) !
Here is the proof :) http://test.qgis.org/ogc_cite/latest_wms_1_3_0.html
<http://test.qgis.org/ogc_cite/latest_wms_1_3_0.html>
[image: Images intégrées 1]
Here is the PR log:
- Fix OGC test on legendurl styles :  #5044
<https://github.com/qgis/QGIS/pull/5044>
- Fixes OGC test on getmap:each-format mode for 1bit/8bit/16bit #5084
<https://github.com/qgis/QGIS/pull/5084>
- Fix OGC test getcapabilities:validate-using-schemaLocation #5145
<https://github.com/qgis/QGIS/pull/5145>
- Fix OGC test getfeatureinfo:invalid-info_format #5150
<https://github.com/qgis/QGIS/pull/5150>
- Fix OGC test getfeatureinfo:invalid-query_layers :  #5157
<https://github.com/qgis/QGIS/pull/5157>
- Fix OGC test getfeatureinfo:each-queryable-layer #5303
<https://github.com/qgis/QGIS/pull/5303>
- Fix OGC test getmap bbox #5360 <https://github.com/qgis/QGIS/pull/5360>
- Fix OGC test recommendations #5566
<https://github.com/qgis/QGIS/pull/5566>
So, now we have a continuous integration in place, what would be nice to do
in the *future* is:
- *Integrate into QGIS travisCI our current gitlab pipeline* that produces
the OGC compliancy reports. The poor Travis probably has a lot of things on
his shoulders by now, but that would be very nice to run those tests on
each build concerning the server.
- *Start working on other services compliancy.* I bet we should start by
WFS and WCS.
- *Get certified by the OGC and make it clearly visible on our website and
documentation !*
See http://www.opengeospatial.org/compliance/getCertified
as part of the OSGEO, I suppose we probably are considered as OGC members
and we probably will need to pay annual fees of 80 $.
If we agree on that, I can contact the OGC to have a clearer idea of those
costs.
Anita, do you know what would be the status of QGIS project as a OGC member
through OGC membership?
Many thanks to all of the contributors! (again)
Best regards,
Régis Haubourg and the Oslandia team
2017-07-10 15:17 GMT+02:00 Régis Haubourg <regis.haubourg at gmail.com>:
> Hi all,
> After getting in sync with 3liz, here is a proposal of task :
> C2C:  1 K€ for making automatic reports with the performance benchmark
> platform
> 3Liz:   6 K€ for GetPrint refactor, and some new feature (WFS 1.1.0 and
> some caching improvements)
> OSLANDIA : 6 K€ for OGC unconformity checks and fixes
> Yves, can you please react upon, that if you have plans to work on png
> encoder improvements?
> Cheers
> Régis
> 2017-07-07 14:02 GMT+02:00 Yves Jacolin <yjacolin at free.fr>:
>> Good point, Emmanuel talked me about this. I need to discuss of this with
>> my
>> collegue first.
>> Y.
>> On vendredi 7 juillet 2017 13:02:20 CEST Andreas Neumann wrote:
>> > Hi Yves,
>> > What about the idea to speed up PNG encoding? I remember that the C2C
>> devs
>> > found out, that the PNG encoder from qt isn't very efficient and a lot
>> of
>> > time is spent by QGIS server on this PNG encoding. An alternative PNG
>> > encoder could be more efficient. Could we invest some ressources in
>> that?
>> > It wouldn't be as urgent as the refactoring, but performance
>> improvements
>> > are always welcome.
>> > Or is the PNG encoder in qt5 now more efficient than the one in qt4?
>> > Andreas
>> > On 7 July 2017 at 10:58, Yves Jacolin <yjacolin at free.fr> wrote:
>> > > Hello Régis,
>> > > On vendredi 7 juillet 2017 10:47:40 CEST Régis Haubourg wrote:
>> > > > @Yves, please raise the hand if you are willing to take some funds
>> on
>> > > > the
>> > > > speed benchmark platform, this would also be very welcome by dev's
>> and
>> > > > customers.
>> > > I was wondering what Camptocamp can do for this as I had confirmation
>> that
>> > > we
>> > > have some resource to work on this part.
>> > > About the speed benchmark plateform we can make it automatic (mainly
>> some
>> > > cleanup, create automatic reporting and improving QGIS automatic build
>> > > with
>> > > docker). For these task we won't need more than 1 k€ though.
>> > > Finally we can also host this in one of our public server but the
>> deploy
>> > > of
>> > > the project should be easy if you need to test somewhere else.
>> > > Y.
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171116/f7bd14a4/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171116/f7bd14a4/attachment.png>
More information about the Qgis-psc mailing list
