[Qgis-psc] QGIS for Mac OS packaging and infrastructure
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Mon Dec 3 06:02:49 PST 2018
I think for CI or PR queue on MacOS we can use travis, where it has nicer
integration with Github and potentially it can scale better.
But I do not see any technical issue with the usage of the dedicated server
too, one can always install some CI on it or use it as a worker.
The broken build was actually caught by cron job building the nightlies,
... I was wondering why the packages are not up-to-date today :)
P.
On Mon, Dec 3, 2018 at 2:57 PM Alessandro Pasotti <apasotti at gmail.com>
wrote:
> On Mon, Dec 3, 2018 at 2:52 PM Peter Petrik <
> peter.petrik at lutraconsulting.co.uk> wrote:
>> Hi,
>> regarding the travis, one concern is that we did not want to have our
>> apple's certificate publicly accessible Also, with dedicated server we have
>> some stability in used libraries (versions). For example when homebrew is
>> used, I think it is not possible to install specific library version (let
>> say gdal x.y.z). On travis, you would end up in installation of the latest
>> version in every build. On dedicated server, you install dependencies once,
>> you build hundreds of nightly builds with one set of dependencies and then
>> create package for LTR/PR with the same set....
>> Kind regards,
>> Peter
> Hi Peter,
> would it be possible to use a dedicate server for CI?
> I'm thinking at the OpenCL issue we had this morning: it would be nice to
> have CI for mac too, so that we can catch that kind of error before merging.
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20181203/9e39fb2d/attachment.html>
More information about the Qgis-psc
