[Qgis-psc] Contributing QGIS testing environment docker
Matthias Kuhn
matthias at opengis.ch
Mon Nov 12 04:09:12 PST 2018
Hi Alessandro,
There is already now a docker image being built on a travis cron job
every night including the full QGIS master, all tagged versions and all
branches and pushed to docker hub (see
https://hub.docker.com/r/qgis/qgis/tags/)
This is built on top of qgis-build-deps (actually qgis-build-deps were
made for this and built on travis too).
If I understand correctly, most of the requirements for the QGIS build
should be there already.
If there are some python scripts missing or other things to be bundled,
that could possibly also go in there.
Would that work, so we could continue to ship a single docker?
Best regards
Matthias
On 09.11.18 09:30, Alessandro Pasotti wrote:
> Hi,
> I've been contacted by Boundless because they are willing to fund the
> move under the QGIS org umbrella of the QGIS testing environment
> docker that I originally created when I was working with them.
> The purpose of the project is to perform CI testing of python plugins
> directly in the QGIS application without using the mocked interface.
> The project is basically a docker that contains:
> - a QGIS build
> - a bunch of python scripts that make it easy to run unit tests in the
> docker
> - documentation and examples about how to use it on travis and
> circle-ci (latter is to be done yet)
> The project is actively maintained (by me) and used by many different
> QGIS plugin projects (at least dozen that I'm aware of).
> The plan is to:
> - refactor the image to start from qgis/qgis3-build-deps
> - move the automated builds from AWS to Circle-CI and (continuously)
> deploy the dockers on docker hub, the following images will be built
> and kept on the hub:
> - master nightly
> - every point release and every release that is not EOL
> - move the repo under
> https://github.com/qgis/qgis-testing-environment-docker
> - (maybe) move the documentation under official QGIS documentation
> (developmen/plugins)
> Project repos:
> https://github.com/elpaso/qgis-testing-environment-docker
> https://github.com/boundlessgeo/qgis-testing-environment-docker
> There should not be any cost for the QGIS organization, as long as the
> builds on Circle-CI remain free and docker hub do not charge for the
> images.
> I think this is a nice contribution to the community!
> So, the question before I start is: are there any objections/concerns?
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20181112/ed798e6b/attachment.html>
More information about the Qgis-psc
