[Qgis-psc] Fwd: Funding for proj6 related fixes/followups?
Anita Graser anitagraser at gmx.at
Wed Dec 11 23:39:33 PST 2019
+1
Anita
On Wed, Dec 11, 2019 at 10:48 PM Andreas Neumann <a.neumann at carto.net>
wrote:
> Hi,
> I am forwarding a request for additional 3-4 days of funding for proj6
> related issues and fixes from Nyall. We still have funding available, so I
> would recommend to support this work.
> Feedback from PSC?
> Thanks,
> Andreas
> -------- Weitergeleitete Nachricht --------
> Betreff: Funding for proj6 related fixes/followups?
> Datum: Thu, 12 Dec 2019 10:18:50 +1300
> Von: Nyall Dawson <nyall at north-road.com> <nyall at north-road.com>
> An: Andreas Neumann <andreas at qgis.org> <andreas at qgis.org>
> Hi Andreas,
> I'm not sure what the situation is with the remaining qgis.org surplus
> for the year, but if there's still money to be spent I think there's
> need for 3-4 days doing follow up work and bug fixes around projection
> and datum transform handling with the QGIS + proj 6 combination.
> The high-priority tasks as I see them are:
> - triage outstanding bug reports between qgis, gdal and proj, and
> identify the underlying issue and responsible library, and coordinate
> fixes (or fix directly in qgis!)
> - allow users to define custom projections using a wkt string instead
> of just proj strings. Proj string definitions of crs are highly
> discouraged in the proj 6+ world, as these are lossly and cannot fully
> encapsulate a CRS. We need a way for users to define custom
> projections using wkt strings, and for the QGIS UI to push them
> towards this (but still allow proj strings if needed)
> - expose the choice of datum transform/coordinate operation used
> inside the Processing vector transform algorithm, allowing users to
> explicitly select which transform pathway they want to use for that
> particular transformation (and allow user created models to also
> expose this option to users when desired)
> Keen to hear your thoughts!
> Nyall
> North Road
> Cartography • Development • Spatial Analysis
> ________________________________
> north-road.com
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20191212/38ea9078/attachment.html>
More information about the Qgis-psc mailing list
