[Qgis-psc] PyQgis Cookbook revision
    Tim Sutton
    tim at kartoza.com
    Fri Dec 20 02:30:29 PST 2019
Hi All
Or put differently, I think the suggestion is to make the cookbook different section of the Python API docs sphinx project so that they are built and managed as one job.
Regards
Tim
> On 20 Dec 2019, at 10:26, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hi Ale,
> Sorry for not being clear.
> Le jeu. 19 déc. 2019 à 16:59, Alessandro Pasotti <apasotti at gmail.com <mailto:apasotti at gmail.com>> a écrit :
> On Thu, Dec 19, 2019 at 4:41 PM Denis Rouzaud <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>> wrote:
> Hi all,
> I was wondering if the cookbook could be integrated with the API docs website.
> It would be nice, we could test everything there (it uses the QGIS docker images), and it would have a single coherente endpoint.
> Ale, feel free to get in touch :)
> Denis
> Hi Denis,
> Do you you mean adding the cookbook directly in the C++ class headers? Like https://github.com/qgis/QGIS/blob/master/src/server/qgsserverogcapi.h#L33 <https://github.com/qgis/QGIS/blob/master/src/server/qgsserverogcapi.h#L33> ?
> This is what QT does, right?
> If that's the case, I've thought about it and there are certainly some advantages: the most important one would probably be a unique source for code, API docs, PyQgis API docs and PyQgis recipes (the cookbook).
> I'm not against it, but I'm not really sure it's the best option: I see the cookbook more like a "book", where there might be more space for longer paragraphs, pictures etc. and where the content can be organized independently from the Qgs* classes structure.
> There are also sections in the cookbook that span across classes (the snippets mainly) or that do not really map to a single Qgs class.
> Yeah, I'm totally with you here. While it sounds like a clever idea at first, you hit so many issues like this which will just make the work much harder at the end.
> In any event, the cookbook also uses a QGIS docker image for the python code tests (qgis/qgis:latest).
> But maybe I totally misunderstood your proposal and you are just talking about moving the current cookbook content into another repo or suck it up when building PyQGIS API docs.
> Yes, I have 2 points:
> * Build the API docs and the cookbook in the same job (but I don't care that much if not)
> * Bring the cookbook under the same website as qgis.org/pyqgis <http://qgis.org/pyqgis> so we have a single entry for all python related stuff.
> Cheers
> Denis
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org <mailto:Qgis-psc at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/qgis-psc <https://lists.osgeo.org/mailman/listinfo/qgis-psc>
Tim Sutton
Co-founder: Kartoza
Ex Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
I'd love to connect. Here's my calendar link <https://calendly.com/timlinux> to make finding time easy.
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20191220/96cd3b76/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20191220/96cd3b76/attachment.jpg>
More information about the Qgis-psc
