[Qgis-psc] QGIS for Mac OS packaging and infrastructure
    Andreas Neumann
    a.neumann at carto.net
    Wed Feb 20 05:54:03 PST 2019
Hi Saber,
There was discussion to help fund the remaining "severe" issues you have
around the MacOS builds.
Can you provide us estimates on how much funds are needed to finish the
following three items (skipping the GRASS issues for now - can be
handled later):
- Lack of Python support for macOS 10.11 and 10.12 - Unable to transfer
of the infrastructure and automatic builds under QGIS.org- from Tim:
Ability to add python packages (maybe adding another python path to
directory in the user’s current profile path
With respect to additional small donations I got: this adds up to approx
100-200 € earmarked towards MacOS. I can forward this to Lutra, however,
if the PSC decides, we might also fund more, so you are able to finish
the above three items.
With respect to Tim's crash:
- Getting a crash when trying to move dock widgets around (in current
LTR build)
Is there a ticket? If yes, this can be handled during the normal bug
fixing cycles. We just treat MacOS like all the other platforms. Nothing
special about it.
Greetings,
Andreas
Am 20.02.19 um 13:11 schrieb Saber Razmjooei:
> Dear PSC, Following our earlier email about QGIS packages for macOS,
> we ran a crowdfunding campaign. Unfortunately, we did not raise enough
> fund to carry out the work we had intended. We had to reduce the scope
> of our work. Below are the known issues/limitations: - Lack of Python
> support for macOS 10.11 and 10.12 - Unable to transfer of the
> infrastructure and automatic builds under QGIS.org - GRASS support in
> the Processing toolbox: most of the modules should work. But GRASS 7.6
> is not fully compatible with Python 3.x and hence some of the
> algorithms might fail. This will be fixed after GRASS 7.8 release. For
> more details, see here:
> https://www.lutraconsulting.co.uk/blog/2019/02/19/qgis-for-macos-update/
> https://lutraconsulting.github.io/qgis-mac-packager/ If you’d like to
> publish the packages, we will need the server details where you’d like
> us to upload the binaries. If the build infrastructure should be moved
> under QGIS.org, we will need QGIS (OSGeo) Apple Developers
> Certificate, macOS Mojave Server with right to install XCode and
> related packages and funds to clean, document and deploy packaging
> code to the official server. Kind regards Saber
> On Thu, 10 Jan 2019 at 07:10, Larry Shaffer <larrys at dakotacarto.com
> <mailto:larrys at dakotacarto.com>> wrote:
>     Hi Nyall, et al.,
>     On Thu, Dec 13, 2018 at 3:16 PM Nyall Dawson
>     <nyall.dawson at gmail.com <mailto:nyall.dawson at gmail.com>> wrote:
>         On Fri, 14 Dec 2018 at 07:42, Tim Sutton <tim at kartoza.com
>         <mailto:tim at kartoza.com>> wrote:
>         > Hi
>         > Ah you are right - thanks! I see the QGIS group widgets have
>         an issue with tehtext staying black in dark mode whilst native
>         Qt widgets correctly show their text in white.
>         It's this line:
>         https://github.com/qgis/QGIS/blob/master/src/app/qgisappstylesheet.cpp#L130
>         I suspect ALL of that custom group box styling should be removed.
>         Trawling through the git history it's over 6 years old, and I
>         strongly
>         suspect that the original styling issues it was designed to
>         workaround
>         are no longer a problem (and that the custom styling is
>         causing more
>         issues now than it is fixing)
>     Indeed. That effort was to bridge issues with different platforms,
>     in an attempt to make things look similar. It is no doubt
>     antiquated by now.
>     Regards,
>     Larry Shaffer
>     Dakota Cartography
>     Black Hills, South Dakota
>         Nyall
>         > Regards
>         > Tim
>         > On Thu, Dec 13, 2018 at 5:29 PM Denis Rouzaud
>         <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>> wrote:
>         >> Hi Tim,
>         >> Are you sure it's the QGIS night mapping theme and not the
>         new look of Qt for Dark Theme?
>         >> Cheers,
>         >> Denis
>         >> Le jeu. 13 déc. 2018 à 11:14, Tim Sutton <tim at kartoza.com
>         <mailto:tim at kartoza.com>> a écrit :
>         >>> Hi
>         >>> Tested with 3.4.2 from last night - still stuck in night
>         mapping mode :-(
>         >>> Regards
>         >>> Tim
>         >>> On 13 Dec 2018, at 10:31, Tim Sutton <tim at kartoza.com
>         >>> Hi
>         >>> Brilliant thanks - downloading now!
>         >>> Regards
>         >>> Tim
>         >>> On 13 Dec 2018, at 09:16, Saber Razmjooei
>         <saber.razmjooei at lutraconsulting.co.uk
>         <mailto:saber.razmjooei at lutraconsulting.co.uk>> wrote:
>         >>> Hi Tim,
>         >>> Both 3.4.2 and master are now built with Qt 5.12. Feel
>         free to give them a try and let us know if you have any other
>         issues.
>         >>> Cheers
>         >>> Saber
>         >>> On Tue, 11 Dec 2018 at 19:24, Tim Sutton <tim at kartoza.com
>         >>>> Cool, thanks!
>         >>>> On Tue, Dec 11, 2018 at 5:34 PM Peter Petrik
>         <peter.petrik at lutraconsulting.co.uk
>         <mailto:peter.petrik at lutraconsulting.co.uk>> wrote:
>         >>>>> qt 5.12 is on my list too:) But both of these are rather
>         small issues with < 1/2 day to solve.
>         >>>>> P.
>         >>>>> On Tue, Dec 11, 2018 at 3:14 PM Denis Rouzaud
>         >>>>>> Hi all,
>         >>>>>> I would propose not to offer multiple installer. The
>         situation is already complex enough. We should at least
>         clearly promote one as the default one.
>         >>>>>> Regarding the night mapping theme, it is a very short
>         time issue (QGIS is unusable in default theme under Mac OS
>         with Dark Theme with Qt < 5.12).
>         >>>>>> I have just updated to Qt 5.12, I am automatically back
>         to default theme and it looks much better!
>         >>>>>> Cheers,
>         >>>>>> Denis
>         >>>>>> Le mar. 11 déc. 2018 à 09:18, Tim Sutton
>         <tim at kartoza.com <mailto:tim at kartoza.com>> a écrit :
>         >>>>>>> Hi
>         >>>>>>> On 11 Dec 2018, at 09:42, Saber Razmjooei
>         >>>>>>> Dear PSC,
>         >>>>>>> From the meeting notes [1], it seems the motion for
>         the PSC to absorb the cost (Point 2 in my email) has been
>         accepted.
>         >>>>>>> Could you clarify:
>         >>>>>>> 1- The PSC is not funding the initial work (Point 1).
>         If so, we'd like to run a crowd-funding campaign. Any
>         promotion from QGIS.org is highly appreciated.
>         >>>>>>> 2- From 3.6 release, the packages generated from the
>         above packaging process will be used under the official
>         download page. This is for our resourcing and crowd-funding
>         purposes, so that we can have everything in place before 3.6
>         release.
>         >>>>>>> Just on this, can I propose we put both your and
>         William’s packages there for the time being? There are some
>         technical differences between the packaging approaches that
>         mean that some users may seek out specifically Williams or
>         Lutra’s packages. My understanding from William is that some
>         of these can be resolved while others cannot easily. For
>         example you cannot install pip packages into the QGIS code
>         signed bundle. Currently with the Lutra packages I am still
>         locked into night mapping theme which I need to file a ticket
>         about still :-P We could collaboratively provide some test
>         with the download outlining which installer is appropriate for
>         which user type.
>         >>>>>>> Regards
>         >>>>>>> Tim
>         >>>>>>> Tim Sutton
>         >>>>>>> tim at qgis.org <mailto:tim at qgis.org>
>         >>>>>>> _______________________________________________
>         >>>>>>> Qgis-psc mailing list
>         >>>>>>> Qgis-psc at lists.osgeo.org <mailto:Qgis-psc at lists.osgeo.org>
>         >>>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
>         >>>>>> Denis Rouzaud
>         >>>>>> denis at opengis.ch <mailto:denis at opengis.ch>
>         >>>>>> +41 76 370 21 22
>         >>>> Tim Sutton
>         >>>> Visit http://kartoza.com to find out about open source:
>         >>>>  * Desktop GIS programming services
>         >>>>  * Geospatial web development
>         >>>> * GIS Training
>         >>>> * Consulting Services
>         >>>> Skype: timlinux Irc: timlinux on #qgis at freenode.net
>         <http://freenode.net>
>         >>>> Tim is a member of the QGIS Project Steering Committee
>         >>>> Kartoza is a merger between Linfiniti and Afrispatial
>         >>> Saber Razmjooei
>         >>> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk>
>         >>> +44 (0)7568 129733
>         >>> <KartozaNewLogoThumbnail.jpg>
>         >>> Tim Sutton
>         >>> Co-founder: Kartoza
>         >>> Ex Project chair: QGIS.org
>         >>> GIS Training
>         >>> Consulting Services
>         >>> Skype: timlinux
>         >>> IRC: timlinux on #qgis at freenode.net <http://freenode.net>
>         >>> Tim Sutton
>         >>> Co-founder: Kartoza
>         >>> GIS Training
>         >>> Consulting Services
>         >>> Skype: timlinux
>         >> Denis Rouzaud
>         >> +41 76 370 21 22
>         > Tim Sutton
>         > * GIS Training
> Saber Razmjooei
> +44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20190220/860d214e/attachment.html>
More information about the Qgis-psc
