[Qgis-psc] AGM Voting matters arising
    Marco Bernasocchi
    marco at qgis.org
    Mon Apr 27 03:31:53 PDT 2020
Hi Andreas
On 27.04.20 11:56, Andreas Neumann wrote:
> Hi,
> I prefer to leave the current version. At one point we need clear
> conditions, otherwise there will be endless discussions when a train
> ride instead of a flight is reasonable or not. If we skip that section
> altogether, then I'd rather have no text at all. It would be so vague,
> that it doesn't really help, in my opinion.
absolutely agree, I'd keep it like that.
> The list of carbon offset companies is not exclusive - I hope that
> this is clear, and if other carbon offset companies are used, that's
> fine - no need to revise the text. I heard rumors that certain
> airlines will have a carbon-offset fee included in the airfare. If a
> future plane ticket shows an extra item for a CO2 compensation, then I
> don't think that there is a need for extra CO2 compensation.
for my last flights on swiss they were already suggesting to compensate
and giving a link to directly do it, I'd be good to have it mandatory
but still already a step forward.
> I don't expect frequent adaptions are required to the current version.
> What would have to change so often?
I don't see that either. I think main point is having or not having such
a policy.
Cheers
Marco
> Thanks,
> Andreas
> Am 27.04.20 um 11:41 schrieb Paolo Cavallini:
>> Hi Andreas,
>> Il 27/04/20 11:22, Andreas Neumann ha scritto:
>>> Hi,
>>> About environmental policy:
>>> the current version is at
>>> https://docs.google.com/document/d/1CQ57w8jz_3MMW7ruIzaB30u4qUODHnoPTC9I7lSIuls/edit
>>> There is one open comment by Vincent. Do you have any remarks on this
>>> comment? If not, then I can generate a PDF version and we can link this
>>> in the voting form - and if accepted - then create the website from the
>>> text.
>> I tend to agree with Vincent, but it's more of a practical issue than a
>> blocker, so I happily leave the decision to you.
>> Cheers.
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Marco Bernasocchi
QGIS.org Co-chair
http://berna.io
More information about the Qgis-psc
