[Qgis-psc] QGIS-Hub proposal
Marco Bernasocchi
marco at qgis.org
Thu Aug 6 09:59:39 PDT 2020
Hi Klas,
wow, looks really nice, thanks a lot! I added this to the next PSC
agenda (1.9.20)
Cheers
Marco
On 06.08.20 13:35, Klas Karlsson wrote:
> Hi
> My name is Klas Karlsson and I dabble with QGIS in my spare time, and
> once in a while I get an idea...
> # Proposal to implement a "QGIS Hub" on the official qgis.org site.
> ## Background
> I was creating a lot of styles just for fun, and was thinking about
> creating a PR to the QGIS GitHub.
> However, a lot of the styles were really intricate and might apply to
> relatively few use cases.
> In stead of filling up the default styles with nice but really
> "un-expandable" styles, there should be
> an easier way.
> Sure, there's the resource sharing plugin, and it works great. But it
> is a lot of steps to go through
> for someone that is only interested in sharing a simple style or two.
> Enter the idea of a "style hub".
> On https://style-hub.github.io I created a demo of how it could look.
> I also created https://layout-hub.github.io
> and that made me realize that there may be a few of these simpler
> resource files that the community
> would like to share, but don't because of the complexity to do so.
> ## QGIS Hub
> So why not at central "Hub" for all kinds of small and easy to share
> resources?
> On https://github.com/style-hub/hub-server/ I started a project to
> create such a hub.
> During the development so far I've used local servers to test it, but
> to get some feed-back
> I also set up a site on free hosting at http://qgis-hub.rf.gd, which
> isn't great since it for instance lack
> TLS/SSL, which is required for some functions, but it should be enough
> to get some user reactions.
> The goal is to create the style-hub first, and then use that to
> "clone" it to a layout-hub too.
> I'm doing this because it's fun and educational, but if it gets
> approval it would probably look good at:
> __hub.qgis.org__
> ## Requirements
> The code is available at GitHub and basically the requirements are:
> * PHP web hosting
> * MySQL database (users and meta data)
> * TLS/SSL for https (required for some functions)
> * Storage space for resource files (write access) (1 Gb will probably
> store well over 1'000 resources)
> I'm willing to continue to work on the site, but I would prefer not to
> do so alone, since I don't
> have the time to drop everything if there's a problem (as mentioned in
> the beginning I'm doing this in my
> spare time).
> My skills at PHP and MySQL is also limited (this is a learning
> experience),
> so the code would probably benefit from some audit, and if the hub is
> to be included in the official site
> I guess it should be styled in the same way, which also would require
> some work.
> For now I will continue to work on the site at http://qgis-hub.rf.gd
> as long as I think it is still fun
> and I have time available.
> Best regards
> Klas Karlsson
> Mail: klas.karlsson at geosupportsystem.se
> Twitter: @klaskarlsson
> YouTube: https://youtube.com/klaskarlsson
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Marco Bernasocchi
QGIS.org Chair
http://berna.io
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200806/8b610642/attachment.html>
More information about the Qgis-psc
